[mapguide-users] JSP and PHP and fusion
Zac Spitzer zac.spitzer at gmail.com
Thu Sep 24 04:04:05 EDT 2009
php is always used for the mapadmin
the sample docs are rather php / c# centric but the api
is the same across all plaforms
you can take any php sample and convert it to JSP
pretty easily
that said, if your comfortable with JSP, stick with JSP
personally i am using the JSP api via coldfusion
(which leaves php for dead, but that's another story!)
z
On Thu, Sep 24, 2009 at 5:33 PM, oshan <icycool at inbox.com> wrote:
> Hey Guys
> So I'm just trying to get started with mapguide. I want to know if there is
> any Documentation specific to using the JSP API. The developers guide seams
> focus on PHP.
> Also what do you guys think is better to use PHP or JSP?
> The reason why I am leaning towards JSP is because it is essentially Java
> programming and I am familiar with Java (altho I have never used JSP)where
> as I have only slight knowledge with PHP and I also have the perception that
> since its Java with the whole OO stuff, it'll prolly be easy to program in!?
> Since I couldn't find any JSP documentation I looked at the sample JSP ajax
> viewer code and it looks a bit scary: there is a whole lot of code! I would
> like to see more of a step by step approach with JSP.
> Also I looked into this fusion thing but it seams a bit buggy. I don't know
> if any of you have experienced that. Like I would specify some widgets but
> they would never show up. I heard that fusion use PHP for it server stuff.
> Does this mean I have to configure mapguide to use PHP instead of JSP. when
> I install it I set it up to use JSP!
> thanks
> View this message in context: http://n2.nabble.com/JSP-and-PHP-and-fusion-tp3704607p3704607.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
