[mapguide-users] Fusion Error: Unterminated string constant
-MySQL Database on hover or select
Fraser Burgess
fburgess at lakelandenergy.com
Thu Sep 24 11:29:53 EDT 2009
Selecting from sdf works no problem. Everything in the map appears to
be working properly. The SQL layers appear to display properly and turn
on and off as expected.
I transcribed the error message wrong - i.e. there is an opening
"@noNameSpaceSchemaLocation. Attached is a screen grab of the error to
be sure.
Fraser
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer
Sent: Thursday, September 24, 2009 11:25 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Fusion Error: Unterminated string constant
looks like the first @noNameSpaceSchemaLocation has no opening " but
has a closing ", hence the whole string has mismatched quotes and
fails to be parsed as a json string and is reported as a unterminated
string constant - unless it didn't paste into your email correctly?
It does not appear to be a problem with your data. Does selecting
anything work (i.e. from shp or sdf files as opposed to SQL)?
Cheers
Paul
On 2009-09-24, at 10:47 AM, Fraser Burgess wrote:
> Hi All,
> I'm using the demo SQL database from redding utilitymap database
> connection. When I connect to the generated layers from this
> dataset In AJAX everything functions as expected.
> In Fusion however, when I hover over or try to select a feature
> displayed on the map I get the following error in a pop up:
> Fusion Error:
> WARNING: Exception occurred in AJAX callback
> Message: Unterminated string constant
> Location: undefined(undefined)
> Response:
> {"FeatureInformation":{FeatureSet":[{@noNamespaceSchemaLocation":
> ["FeatureSet-1/0/0xsd"],"Layer";[{"@id:
> ["e64a6900-8b44-102c-8000-005056c0008"],"Class";[{"@id":
> ["Deafulat:worlder"] ........................................... Etc,
etc,
> Not sure what is up but I noticed part of this error message looks
> like an AJAX session parameter. Not sure if that provides any hints
> Any ideas what this might be caused by?
> Thanks,
> Fraser
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Type: image/png
Desc: fusionerror.png
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090924/07b9e561/fusionerror.png
