[mapguide-users] Fusion Error: Unterminated string constant - MySQL Database on hover or select
Paul Spencer pagameba at gmail.com
Thu Sep 24 11:24:38 EDT 2009
looks like the first @noNameSpaceSchemaLocation has no opening " but
has a closing ", hence the whole string has mismatched quotes and
fails to be parsed as a json string and is reported as a unterminated
string constant - unless it didn't paste into your email correctly?
It does not appear to be a problem with your data.  Does selecting
anything work (i.e. from shp or sdf files as opposed to SQL)?
Cheers
Paul
On 2009-09-24, at 10:47 AM, Fraser Burgess wrote:
> Hi All,
> I’m using the demo SQL database from redding utilitymap database
> connection.  When I connect to the generated layers from this
> dataset In AJAX everything functions as expected.
> In Fusion however, when I hover over or try to select a feature
> displayed on the map I get the following error in a pop up:
> Fusion Error:
> WARNING: Exception occurred in AJAX callback
> Message: Unterminated string constant
> Location: undefined(undefined)
> Response:
> {“FeatureInformation”:{FeatureSet”:[{@noNamespaceSchemaLocation”:
> [“FeatureSet-1/0/0xsd”],”Layer”;[{“@id:
> [“e64a6900-8b44-102c-8000-005056c0008”],”Class”;[{“@id”:
> [“Deafulat:worlder”] ……………………………………. Etc, etc,
> Not sure what is up but I noticed part of this error message looks
> like an AJAX session parameter.  Not sure if that provides any hints
> Any ideas what this might be caused by?
> Thanks,
> Fraser
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
