[mapguide-users] Dynamically Setting Initial Map Position and Scale
Nickthetemp nickthetemp at gmail.com
Fri Sep 25 10:54:52 EDT 2009
I know this is an older post but I was having the same problem.
You must change the setting in studio for the intial zoom to be custom. When
it is set to use the maps initail zoom this code does not work.
Beverage wrote:
> Afternoon all,
> I'm hoping someone will be able to look through the code I have to
> dynamically set the initial map position and scale. I have taken this
> straight from the code sample
> (http://trac.osgeo.org/mapguide/wiki/CodeSamples/PHP/InitialMapView) but
> when I run it, it just opens the map up at the default scale level. Any
> help would be greatly appreciated...
> I am passing in X, Y and Scale as parameters within the query string.
>         global $_itkconfig, $session;
>          //this code is used to display the Open Source MapGuide Web
> Layout screen
>          //common file from MapGuide Open Source
>          require_once('..\data\common.php');
>          //need to include the MapGuide Open Source constants file for
> PHP
> require_once($_itkconfig['site']['mapObject']['viewerDir'].'constants.ph
> p');
>       // Check and get the required parameters.
>       if (!isset($_REQUEST["x"]) || !isset($_REQUEST["y"]) ||
> !isset($_REQUEST["scale"])) {
>           echo "<Error>One or more of the required arguments is
> missing.</Error>";
>           exit;
>       $x = $_REQUEST["x"];
>       $y = $_REQUEST["y"];
>       $scale = $_REQUEST["scale"];
>         // Usual initialisation step.
> MgInitializeWebTier($_itkconfig['site']['mapObject']['webConfigFilePath'
>         // Obtain a new session ID for this anonymous user, use it to
> set up
>         // a new site connection and use that to create a resource
> service.
>         $site = new MgSite();
>         $site->Open(new MgUserInformation("Anonymous", ""));
>         $sessionId = $site->CreateSession();
>         $siteConnection = new MgSiteConnection();
>         $siteConnection->Open(new MgUserInformation($sessionId));
>         $resourceService =
> $siteConnection->CreateService(MgServiceType::ResourceService);
>         // Read the web layout into an XML DOM document object.
>         $wl = "Library:// Layouts/Development_Layout.WebLayout"; // TODO
> Constant!
>         $wlResourceId = new MgResourceIdentifier($wl);
>         $wlReader = $resourceService->GetResourceContent($wlResourceId);
>         $wlXml = $wlReader->ToString();
>         $wlDomDoc = DOMDocument::loadXML($wlXml);
>         // Now, update the initial x, y and scale values with the
> desired values.
>         $nodeCenterX =
> $wlDomDoc->getElementsByTagName("CenterX")->item(0);
>         $nodeCenterX->nodeValue = "$x";
>         $nodeCenterY =
> $wlDomDoc->getElementsByTagName("CenterY")->item(0);
>         $nodeCenterY->nodeValue = "$y";
>         $nodeScale = $wlDomDoc->getElementsByTagName("Scale")->item(0);
>         $nodeScale->nodeValue = "$scale";
>         // Prepare the updated XML to be written out to the session.
>         $updatedXml = $wlDomDoc->saveXML();
>         $byteSource = new MgByteSource($updatedXml,
> strlen($updatedXml));
>         // Create a web layout in the session to hold the updated
> version
>         // from the library.
>         $sessionMapName = $wlResourceId->GetName();
>         $sessionWebLayout =
> "Session:$sessionId//$sessionMapName.WebLayout";
>         $sessionResourceId = new
> MgResourceIdentifier($sessionWebLayout);
>         // Write the updated web layout to the session.
>         $resourceService->SetResource($sessionResourceId,
> $byteSource->GetReader(), null);
>         // Redirect to the Ajax viewer pointing at the map at the
> desired coordinates.
>         $redirectTo =
> "mapguide/mapviewerajax/?SESSION=$sessionId&WEBLAYOUT=$sessionWebLayout"
>         $url = "http://localhost:8008/$redirectTo";
>         header("Location: $url");
>         exit;
> Thanks,
> Bev
> This email and any attachment are intended solely for the addressee, are
> strictly confidential and may be legally privileged. If you are not the
> intended recipient any reading, dissemination, copying or any other use or
> reliance is prohibited. If you have received this email in error please
> notify the sender immediately by email and then permanently delete the
> email. Copyright reserved.
> All communications, incoming and outgoing, may be recorded and are
> monitored for legitimate business purposes.
> The security and reliability of email transmission cannot be guaranteed.
> It is the recipient’s responsibility to scan this e-mail and any
> attachment for the presence of viruses.
> The Capita Group plc and its subsidiaries ("Capita") exclude all liability
> for any loss or damage whatsoever arising or resulting from the receipt,
> use or transmission of this email.
> Any views or opinions expressed in this email are those of the author
> only.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Dynamically-Setting-Initial-Map-Position-and-Scale-tp1818865p3712803.html
