[mapguide-users] Create Featuresource
Jackie Ng
jumpinjackie at gmail.com
Tue Sep 29 10:00:40 EDT 2009
These dlls are from the FDO SDK?
Make sure that *all* the dlls (and providers.xml) from your FDO SDK are in
the output directory
- Jackie
Gunter Becker wrote:
> Thank you Jackie,
> I've put all the managed and unmanaged dll's from the windows binaries in
> the bin folder of my WebApplication and tried to follow your steps but I
> got an error message :
> File or assembly "file:///C:\Users\gunter.becker\Documents\Visual Studio
> 2008\Projects\CSOGIS\bin\ExpressionEngine.dll" or one of its dependencies,
> was not found. The module was expected to contain an assembly manifest.
> Do you know if I miss something?
> Gunter
> Jackie Ng wrote:
>> FDO is the way to go. As Kenneth already mentioned, this approach won't
>> be portable unless you want to dive into the native C++ API. The Managed
>> FDO API is only available for Windows.
>> To do this, you will have to do the following:
>> FDO side:
>> 1. Create a FDO connection to the desired provider
>> 2. Create and execute an ICreateDataStore command
>> 3. Build your FDO feature schema (similar to MapGuide)
>> 4. Create and execute an IApplySchema command, with the schema you built.
>> Then it's over to the MapGuide side:
>> 1. Create a new feature source xml document with the same connection
>> settings
>> 2. Save this into your site repository using MgResourceService.
>> The MapGuide 2.2 APIs will eventually remove the need to use FDO directly
>> for some providers (the non-RDBMS ones)
>> - Jackie
>>> Hi,
>>> I want to create a new featuresource (shp, sdf or SQL Server 2008
>>> Spatial) from my webapplication (c# .NET). I got it working for a sdf
>>> FeatureSource with the MapGuideAPI. But I'm wondering if it is possible
>>> for SHP or SQL Server Spatial at all. What are the steps to create an
>>> shape-file in the repository or as an external file and what are the
>>> steps to create a spatial database table. Is there an easy way to do
>>> this with the MaestroAPI. Or do I have to use the FdoAPI ?
>>> Thanks, Gunter
View this message in context: http://n2.nabble.com/Create-Featuresource-tp3735230p3736449.html
