[mapguide-users] Create Featuresource
Gunter Becker gunter.becker at csogis.de
Tue Sep 29 09:50:29 EDT 2009
Thank you Jackie,
I've put all the managed and unmanaged dll's from the windows binaries in
the bin folder of my WebApplication and tried to follow your steps but I got
an error message :
File or assembly  "file:///C:\Users\gunter.becker\Documents\Visual Studio
2008\Projects\CSOGIS\bin\ExpressionEngine.dll" or one of its dependencies,
was not found. The module was expected to contain an assembly manifest.
Do you know if I miss something?
Gunter
Jackie Ng wrote:
> FDO is the way to go. As Kenneth already mentioned, this approach won't be
> portable unless you want to dive into the native C++ API. The Managed FDO
> API is only available for Windows.
> To do this, you will have to do the following:
> FDO side:
> 1. Create a FDO connection to the desired provider
> 2. Create and execute an ICreateDataStore command
> 3. Build your FDO feature schema (similar to MapGuide)
> 4. Create and execute an IApplySchema command, with the schema you built.
> Then it's over to the MapGuide side:
> 1. Create a new feature source xml document with the same connection
> settings
> 2. Save this into your site repository using MgResourceService.
> The MapGuide 2.2 APIs will eventually remove the need to use FDO directly
> for some providers (the non-RDBMS ones)
> - Jackie
> Gunter Becker wrote:
>> Hi,
>> I want to create a new featuresource (shp, sdf or SQL Server 2008
>> Spatial) from my webapplication (c# .NET). I got it working for a sdf
>> FeatureSource with the MapGuideAPI. But I'm wondering if it is possible
>> for SHP or SQL Server Spatial at all. What are the steps to create an
>> shape-file in the repository or as an external file and what are the
>> steps to create a spatial database table. Is there an easy way to do this
>> with the MaestroAPI. Or do I have to use the FdoAPI ?
>> Thanks, Gunter
View this message in context: http://n2.nabble.com/Create-Featuresource-tp3735230p3736387.html
