[mapguide-users] Create Featuresource
Jackie Ng jumpinjackie at gmail.com
Tue Sep 29 10:41:30 EDT 2009
Do you have the Visual C++ 2008 runtime library installed?
If so, I wonder then if it is because you are using this in an ASP.net
environment and that is somehow messing with the paths?
- Jackie
Gunter Becker wrote:
> OK, I tried it with the SDK files and know I got the error message:
> "The specified module could not be found"
> Any ideas?
> Gunter
>> No, these files are from "FDO API and Common Binaries" under "Windows
>> Binaries". Does it make a difference?
>> I'll download the SDK files an give this a try!
>> Gunter
>> Jackie Ng wrote:
>>> These dlls are from the FDO SDK?
>>> Make sure that *all* the dlls (and providers.xml) from your FDO SDK are
>>> in the output directory
>>> - Jackie
>>>> Thank you Jackie,
>>>> I've put all the managed and unmanaged dll's from the windows binaries
>>>> in the bin folder of my WebApplication and tried to follow your steps
>>>> but I got an error message :
>>>> File or assembly  "file:///C:\Users\gunter.becker\Documents\Visual
>>>> Studio 2008\Projects\CSOGIS\bin\ExpressionEngine.dll" or one of its
>>>> dependencies, was not found. The module was expected to contain an
>>>> assembly manifest.
>>>> Do you know if I miss something?
>>>> Gunter
>>>> Jackie Ng wrote:
>>>>> FDO is the way to go. As Kenneth already mentioned, this approach
>>>>> won't be portable unless you want to dive into the native C++ API. The
>>>>> Managed FDO API is only available for Windows.
>>>>> To do this, you will have to do the following:
>>>>> FDO side:
>>>>> 1. Create a FDO connection to the desired provider
>>>>> 2. Create and execute an ICreateDataStore command
>>>>> 3. Build your FDO feature schema (similar to MapGuide)
>>>>> 4. Create and execute an IApplySchema command, with the schema you
>>>>> built.
>>>>> Then it's over to the MapGuide side:
>>>>> 1. Create a new feature source xml document with the same connection
>>>>> settings
>>>>> 2. Save this into your site repository using MgResourceService.
>>>>> The MapGuide 2.2 APIs will eventually remove the need to use FDO
>>>>> directly for some providers (the non-RDBMS ones)
>>>>> - Jackie
>>>>>> Hi,
>>>>>> I want to create a new featuresource (shp, sdf or SQL Server 2008
>>>>>> Spatial) from my webapplication (c# .NET). I got it working for a sdf
>>>>>> FeatureSource with the MapGuideAPI. But I'm wondering if it is
>>>>>> possible for SHP or SQL Server Spatial at all. What are the steps to
>>>>>> create an shape-file in the repository or as an external file and
>>>>>> what are the steps to create a spatial database table. Is there an
>>>>>> easy way to do this with the MaestroAPI. Or do I have to use the
>>>>>> FdoAPI ?
>>>>>> Thanks, Gunter
View this message in context: http://n2.nabble.com/Create-Featuresource-tp3735230p3736680.html
