[mapguide-users] Create Featuresource
Gunter Becker gunter.becker at csogis.de
Tue Sep 29 10:55:12 EDT 2009
Using the SDK File in a WindowsApplication works for me!
But I would like to manage the creation of a feature source in the
WebApplication.
I think I have the C++ runtime library installed but I don't know exactly.
How can I determine that I have Visual C++ 2008 runtime library installed? I
don't need it becaus I#m not a C++ programmer! So do you think uninstalling
the runtime library could solve my problem?
Gunter
Jackie Ng wrote:
> Do you have the Visual C++ 2008 runtime library installed?
> If so, I wonder then if it is because you are using this in an ASP.net
> environment and that is somehow messing with the paths?
> - Jackie
> Gunter Becker wrote:
>> OK, I tried it with the SDK files and know I got the error message:
>> "The specified module could not be found"
>> Any ideas?
>> Gunter
>>> No, these files are from "FDO API and Common Binaries" under "Windows
>>> Binaries". Does it make a difference?
>>> I'll download the SDK files an give this a try!
>>> Gunter
>>> Jackie Ng wrote:
>>>> These dlls are from the FDO SDK?
>>>> Make sure that *all* the dlls (and providers.xml) from your FDO SDK are
>>>> in the output directory
>>>> - Jackie
>>>>> Thank you Jackie,
>>>>> I've put all the managed and unmanaged dll's from the windows binaries
>>>>> in the bin folder of my WebApplication and tried to follow your steps
>>>>> but I got an error message :
>>>>> File or assembly  "file:///C:\Users\gunter.becker\Documents\Visual
>>>>> Studio 2008\Projects\CSOGIS\bin\ExpressionEngine.dll" or one of its
>>>>> dependencies, was not found. The module was expected to contain an
>>>>> assembly manifest.
>>>>> Do you know if I miss something?
>>>>> Gunter
>>>>> Jackie Ng wrote:
>>>>>> FDO is the way to go. As Kenneth already mentioned, this approach
>>>>>> won't be portable unless you want to dive into the native C++ API.
>>>>>> The Managed FDO API is only available for Windows.
>>>>>> To do this, you will have to do the following:
>>>>>> FDO side:
>>>>>> 1. Create a FDO connection to the desired provider
>>>>>> 2. Create and execute an ICreateDataStore command
>>>>>> 3. Build your FDO feature schema (similar to MapGuide)
>>>>>> 4. Create and execute an IApplySchema command, with the schema you
>>>>>> built.
>>>>>> Then it's over to the MapGuide side:
>>>>>> 1. Create a new feature source xml document with the same connection
>>>>>> settings
>>>>>> 2. Save this into your site repository using MgResourceService.
>>>>>> The MapGuide 2.2 APIs will eventually remove the need to use FDO
>>>>>> directly for some providers (the non-RDBMS ones)
>>>>>> - Jackie
>>>>>>> Hi,
>>>>>>> I want to create a new featuresource (shp, sdf or SQL Server 2008
>>>>>>> Spatial) from my webapplication (c# .NET). I got it working for a
>>>>>>> sdf FeatureSource with the MapGuideAPI. But I'm wondering if it is
>>>>>>> possible for SHP or SQL Server Spatial at all. What are the steps to
>>>>>>> create an shape-file in the repository or as an external file and
>>>>>>> what are the steps to create a spatial database table. Is there an
>>>>>>> easy way to do this with the MaestroAPI. Or do I have to use the
>>>>>>> FdoAPI ?
>>>>>>> Thanks, Gunter
View this message in context: http://n2.nabble.com/Create-Featuresource-tp3735230p3736765.html
