[mapguide-users] Create Featuresource
Jackie Ng
jumpinjackie at gmail.com
Tue Sep 29 11:05:45 EDT 2009
FDO needs the VC++ runtime library. The OSGeo.FDO.*.dll files are .net
wrappers around the native libraries which use the VC++ runtime. Do not
uninstall it.
The fact that you have it working in a windows application means that you
have the runtime library installed. It also means that there is definitely
something to do with it being a web application, that's causing FDO to fail.
What that is, I do know at the moment.
- Jackie
Gunter Becker wrote:
> Using the SDK File in a WindowsApplication works for me!
> But I would like to manage the creation of a feature source in the
> WebApplication.
> I think I have the C++ runtime library installed but I don't know exactly.
> How can I determine that I have Visual C++ 2008 runtime library installed?
> I don't need it becaus I#m not a C++ programmer! So do you think
> uninstalling the runtime library could solve my problem?
> Gunter
> Jackie Ng wrote:
>> Do you have the Visual C++ 2008 runtime library installed?
>> If so, I wonder then if it is because you are using this in an ASP.net
>> environment and that is somehow messing with the paths?
>> - Jackie
>>> OK, I tried it with the SDK files and know I got the error message:
>>> "The specified module could not be found"
>>> Any ideas?
>>> Gunter
>>>> No, these files are from "FDO API and Common Binaries" under "Windows
>>>> Binaries". Does it make a difference?
>>>> I'll download the SDK files an give this a try!
>>>> Gunter
>>>> Jackie Ng wrote:
>>>>> These dlls are from the FDO SDK?
>>>>> Make sure that *all* the dlls (and providers.xml) from your FDO SDK
>>>>> are in the output directory
>>>>> - Jackie
>>>>>> Thank you Jackie,
>>>>>> I've put all the managed and unmanaged dll's from the windows
>>>>>> binaries in the bin folder of my WebApplication and tried to follow
>>>>>> your steps but I got an error message :
>>>>>> File or assembly "file:///C:\Users\gunter.becker\Documents\Visual
>>>>>> Studio 2008\Projects\CSOGIS\bin\ExpressionEngine.dll" or one of its
>>>>>> dependencies, was not found. The module was expected to contain an
>>>>>> assembly manifest.
>>>>>> Do you know if I miss something?
>>>>>> Gunter
>>>>>> Jackie Ng wrote:
>>>>>>> FDO is the way to go. As Kenneth already mentioned, this approach
>>>>>>> won't be portable unless you want to dive into the native C++ API.
>>>>>>> The Managed FDO API is only available for Windows.
>>>>>>> To do this, you will have to do the following:
>>>>>>> FDO side:
>>>>>>> 1. Create a FDO connection to the desired provider
>>>>>>> 2. Create and execute an ICreateDataStore command
>>>>>>> 3. Build your FDO feature schema (similar to MapGuide)
>>>>>>> 4. Create and execute an IApplySchema command, with the schema you
>>>>>>> built.
>>>>>>> Then it's over to the MapGuide side:
>>>>>>> 1. Create a new feature source xml document with the same connection
>>>>>>> settings
>>>>>>> 2. Save this into your site repository using MgResourceService.
>>>>>>> The MapGuide 2.2 APIs will eventually remove the need to use FDO
>>>>>>> directly for some providers (the non-RDBMS ones)
>>>>>>> - Jackie
>>>>>>>> Hi,
>>>>>>>> I want to create a new featuresource (shp, sdf or SQL Server 2008
>>>>>>>> Spatial) from my webapplication (c# .NET). I got it working for a
>>>>>>>> sdf FeatureSource with the MapGuideAPI. But I'm wondering if it is
>>>>>>>> possible for SHP or SQL Server Spatial at all. What are the steps
>>>>>>>> to create an shape-file in the repository or as an external file
>>>>>>>> and what are the steps to create a spatial database table. Is there
>>>>>>>> an easy way to do this with the MaestroAPI. Or do I have to use the
>>>>>>>> FdoAPI ?
>>>>>>>> Thanks, Gunter
View this message in context: http://n2.nabble.com/Create-Featuresource-tp3735230p3736837.html
