[mapguide-users] Fixing a corrupt repository
Bill T btenbroeck at gmail.com
Sun Apr 18 10:13:51 EDT 2010
I have copied a Library folder from the Root using Maestro, and was going to
take care of all the renaming etc. using it. However, once I did that, the
system began tossing an error, and stopping/starting the mapguide service
would not fix it - only re-booting the machine. And even at that, it would
last through one operation, and back to the same thing, including rebooting
the server. I intend to discuss this in a Maestro post, but at this point,
I'm looking for a way to fix the repository.  In the RepositoryAdmin.pdf it
says the following:
"Restart the server. The server will automatically try to fix the
repository.
There is still a chance that a recovery may fail if any of the repository
files have been
deleted or are too badly damaged."
That doesn't sound too encouraging, as there is not any info on a Repository
that is "too badly damaged"
Has anyone seen and fixed this before?
Thanks,
Bill
View this message in context: http://n2.nabble.com/Fixing-a-corrupt-repository-tp4920923p4920923.html
