[mapguide-users] Re: Viewer API GetLayer() and base layers
Tom Chadwin
tom.chadwin at nnpa.org.uk
Wed Apr 21 06:52:40 EDT 2010
That's the page Praveen pointed me towards, and which I was trying to use as
a model. However, the two events it shows you how to hook into are the
completion of the loading of the map, and OnSelectionChaged. I need to hook
into RequestMap(), which is a function, not an event of any kind, as far as
my limited understanding tells me.
Unless someone can give me a technique to achieve that, I'll go back to
hacking the original function, and am aware of the problem of losing that
customization when upgrading MapGuide.
One other issue I have is caching of my xmlhttp request. I can work around
this by adding a random parameter to the query, but realize this is a hack.
I am now experimenting with adding cache control headers on the server side.
Does anyone know of the best way to achieve this (fully cross-browser
compatible)?
Thanks
Tom
View this message in context: http://n2.nabble.com/Viewer-API-GetLayer-and-base-layers-tp4792901p4936267.html
