[mapguide-users] Modify Scale Ranges Of a Layers
Jason Birch
jason at jasonbirch.com
Fri Apr 23 02:13:14 EDT 2010
The Session repository only stores resources for as long as the session
exists. You will need to persist the layer definition somewhere in the
Library repository, and then figure out how to retrieve it next time the
user accesses your application. Be aware that the anonymous user is not
permitted to write to the Library repository, so your app will need to
authenticate as a different user to do this.
Jason
On 22 April 2010 22:51, SriRam007 wrote:
> I want to keep permanently the modified scale ranges of a layers.
> I already have done By modifing the XML file of Layerdefinition for
> changing
> the scale dynamically.
> And it is working fine also. But it exists till the session end. I want to
> keep it permanently.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100422/7ff4636a/attachment.html
