kfwebb at bombasticlocution.com
Sun Apr 25 10:34:08 EDT 2010
This issue was solved via a posting in another thread.
In Re: [mapguide-users] RE: Maroon Theme and tooltips doesn't show
Mike Adair suggested editing jxtheme.css to change all 10000 widths
to 1000.
There was only one 10K value in the delicious/jxtheme.css file I am
referencing and that was for the jxBarScroller object.
Thanks Mike!
KFW
On Sun, 2010-04-18 at 13:36 -0400, kfwebb at bombasticlocution.com wrote:
> Greetings!
> I am working with the templates/mapguide/standard fusion viewer that was
> bundled in mapguideopensource-2.1.0.4283-src.tar.gz. When using Firefox
> v3.6.3 none of the Toolbar icons are showing after the mapviewer has
> rendered. All of the Toolbar objects are there, I get tooltips when I
> mouse over the Toolbar, and can successfully change tool-mode by
> and icons.css are loading properly. When working with the same fusion
> mapviewer using Safari 3.0.4 everything shows and is working splendidly.
> Firefox 3.6.3 - All functionality, and all widgets except for Toolbar
> icons.
> Safari 3.0.4 - All functionality and all widgets.
> Firefox 2.0.0.8 "Too much recursion error" (Just included this as an
> FYI)
> Any suggestions?
> Thank you.
> KFW
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
