[mapguide-users] Re: At my wit's end...
Zac Spitzer
zac.spitzer at gmail.com
Sat Aug 7 23:31:24 EDT 2010
have you tried linking the excel table into access and accessing that?
otherwise, you could just load the spreadsheet into a real database
which will just work....
excel isn't exactly the best choice of datasource
sometimes if the angle your trying isn't working, it's best to re-evaluate
your approach and adopt one which is more traditional
z
On 8 August 2010 02:54, isca <mapguide2007 at gmail.com> wrote:
> Could have to do with the column names ... I noticed that fdo is not
> responding always fine to special characters in the column names -> in this
> case ( might be the problem.
> In order to locate the problem you could start to strip off the excel sheet.
> This helped me already a lot in the past.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/At-my-wit-s-end-tp5381123p5383924.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
