[mapguide-users] RE: Window Selection (Ajax) as ENVELOPE or
INTERESECTS Confusion
Crispin_at_1Spatial
crispin.hoult at 1spatial.com
Tue Aug 10 04:16:58 EDT 2010
Andreas,
Thanks for the help. The changes you note were to support 9i - but
something else has gone awry!
http://trac.osgeo.org/fdo/ticket/619
I am building the latest KingOra from the 3.5 branch and compiling into the
Release_FDO_3_4 configuration and I don't see the old "1SPATIAL" comments in
the source anymore:
http://svn.osgeo.org/fdo/branches/3.5/Providers/KingOracle/src/Provider/c_KgOraFilterProcessor.cpp
However, can you please conform that the code block you changed was in the
switch/case for envelope intersects?
If so then the original problem is still valid - because where
"&SELECTIONVARIANT=INTERSECTS" this should not be calling the FDO operation
for FdoSpatialOperations_EnvelopeIntersects.
Crispin
switch( Filter.GetOperation() )
case FdoSpatialOperations_EnvelopeIntersects
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Window-Selection-Ajax-as-ENVELOPE-or-INTERESECTS-Confusion-tp5389467p5392125.html
