[mapguide-users] RE: Window Selection (Ajax) as ENVELOPE or INTERESECTS Confusion
Andreas Morf a.morf at fkl.ch
Tue Aug 10 08:43:34 EDT 2010
Crispin,
No, unfortunately not, the block I changed was within 'case FdoSpatialOperations_Intersects' where we should have the exact
intersection result set. With my configuration, this code block is called when selecting features or generating maptips.
Andreas
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf
> Of Crispin_at_1Spatial
> Sent: Tuesday, August 10, 2010 10:17 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: Window Selection (Ajax) as ENVELOPE or INTERESECTS Confusion
> Andreas,
> Thanks for the help.  The changes you note were to support 9i - but
> something else has gone awry!
> http://trac.osgeo.org/fdo/ticket/619
> I am building the latest KingOra from the 3.5 branch and compiling into the
> Release_FDO_3_4 configuration and I don't see the old "1SPATIAL" comments in
> the source anymore:
> http://svn.osgeo.org/fdo/branches/3.5/Providers/KingOracle/src/Provider/c_KgOraFilterProcessor.cpp
> However, can you please conform that the code block you changed was in the
> switch/case for envelope intersects?
> If so then the original problem is still valid - because where
> "&SELECTIONVARIANT=INTERSECTS" this should not be calling the FDO operation
> for FdoSpatialOperations_EnvelopeIntersects.
>  Crispin
> switch( Filter.GetOperation() )
>   case FdoSpatialOperations_EnvelopeIntersects
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Window-Selection-Ajax-as-
> ENVELOPE-or-INTERESECTS-Confusion-tp5389467p5392125.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
