[mapguide-users] Re: Subject: Best practices for running Fusion
within frames
Warren Medernach
wmedernach at gmail.com
Mon Aug 9 13:31:03 EDT 2010
Ok, so I struggled with this for a bit and between some vacation time and
other projects, I'm just getting back to this...
I wanted to get this down to hopefully help others and also to raise a
question.
As previously discussed in this thread I have a frame based MG site using
the Fusion viewer. Now, even though I am calling this Search command in a
specified frame I noticed that the URL string variable popup is set to true.
I had orignally assumed that 'popup' meant a seperate window opening, but I
guess it means any other window/frame besides the Task Pane. Once I
realized this I was able to adjust the GetParent call to hit the correct
frame.
Now for the question: would it not make sense for the popup variable only to
be set when the New Window option is chosen?
ps. I also like Gordon's method of iFrames and all of the jscript in the top
Fusion index page.
Warren
On Fri, Jul 30, 2010 at 8:54 PM, Jason Birch <jason at jasonbirch.com> wrote:
> Interesting, and Warren's use too.
> I wonder how much of this could be met directly with custom templates when
> using Fusion, but probably easier to manage with iframes, and gives you AJAX
> viewer embeds too.
> On 30 July 2010 12:32, GordonL wrote:
>> Hi Jason, I use IFRAMES for both the AJAX and FUSION versions (I use
>> modified
>> templates too). The nice thing is that all my javascript in in the index
>> page so i just call everything with a top.functionName() regardless of
>> viewer type.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100809/37ee12d5/attachment.html
