[mapguide-users] Re: King Oracle Provider not available on Ubuntu installation
avdschyff avdschyff at gmail.com
Thu Aug 12 03:45:00 EDT 2010
Thanks, that solved my problem. After adding it in providers.xml I can now
see the King.Oracle provider. It doesn't seem like the GUI to configure it
is presenting correctly under Mono though, I will try and access it from
Windows to see if I can get it configured. Otherwise I might try using the
ODBC provider with unixodbc.
Thanks,
Andre
On Wed, Aug 11, 2010 at 7:11 PM, Haris Kurtagic [via OSGeo.org] <
ml-node+5413130-396697722-284645 at n2.nabble.com<ml-node%2B5413130-396697722-284645 at n2.nabble.com>
> wrote:
> Perhaps missing entry in providers.xml file ?
> Still, I think there will be problems running with King.Oracle on Linux.
> Issue started in version in which I used wide characters for sql strings.
> Oracle client has same wide character size on both linux and windows.
> Not much work to fix it, but ...
> Haris
> On Wed, Aug 11, 2010 at 3:43 PM, avdschyff <[hidden email]<http://user/SendEmail.jtp?type=node&node=5413130&i=0>>
> wrote:
> > I'm still new to MapGuide and unfortunately I'm stumped on this issue. I
> > installed Mapguide on Ubuntu 9.10 i386 using the instructions on
> http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22/LinuxBuildProcess.
> > After the installation I managed to get the server going and installed
> > Maestro. When trying to create a DataConnection I see no King Oracle
> > provider listed.
> > I have installed the Oracle instant client and exported the directory on
> my
> > LD_LIBRARY_PATH before starting the server. I've also checked
> > /usr/local/fdo-3.5.0/lib and see the provider there
> > (libKingOracleProvider.so). I've also checked serverconfig.ini, and
> FdoPath
> > is /usr/local/fdo-3.5.0/lib.
> > Our existing data is in an Oracle DB so I think I will need this, any
> help
> > would be appreciated.
> > Thanks
> > Andre
> > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/King-Oracle-Provider-not-available-on-Ubuntu-installation-tp5412286p5412286.html<http://osgeo-org.1803224.n2.nabble.com/King-Oracle-Provider-not-available-on-Ubuntu-installation-tp5412286p5412286.html?by-user=t>
> > Sent from the MapGuide Users mailing list archive at Nabble.com.
> > mapguide-users mailing list
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=5413130&i=1>
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5413130&i=2>
>  View message @
> http://osgeo-org.1803224.n2.nabble.com/King-Oracle-Provider-not-available-on-Ubuntu-installation-tp5412286p5413130.html
> To unsubscribe from King Oracle Provider not available on Ubuntu
> installation, click here<http://osgeo-org.1803224.n2.nabble.com/template/NodeServlet.jtp?tpl=unsubscribe_by_code&node=5412286&code=YXZkc2NoeWZmQGdtYWlsLmNvbXw1NDEyMjg2fDE2NjA1NzIwMjc=>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/King-Oracle-Provider-not-available-on-Ubuntu-installation-tp5412286p5415209.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100812/7fc09ed7/attachment.html
