[mapguide-users] King Oracle Provider not available on Ubuntu
installation
Haris Kurtagic
haris at sl-king.com
Wed Aug 11 13:11:09 EDT 2010
Perhaps missing entry in providers.xml file ?
Still, I think there will be problems running with King.Oracle on Linux.
Issue started in version in which I used wide characters for sql strings.
Oracle client has same wide character size on both linux and windows.
Not much work to fix it, but ...
Haris
On Wed, Aug 11, 2010 at 3:43 PM, avdschyff <avdschyff at gmail.com> wrote:
> I'm still new to MapGuide and unfortunately I'm stumped on this issue. I
> installed Mapguide on Ubuntu 9.10 i386 using the instructions on
> http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22/LinuxBuildProcess.
> After the installation I managed to get the server going and installed
> Maestro. When trying to create a DataConnection I see no King Oracle
> provider listed.
> I have installed the Oracle instant client and exported the directory on my
> LD_LIBRARY_PATH before starting the server. I've also checked
> /usr/local/fdo-3.5.0/lib and see the provider there
> (libKingOracleProvider.so). I've also checked serverconfig.ini, and FdoPath
> is /usr/local/fdo-3.5.0/lib.
> Our existing data is in an Oracle DB so I think I will need this, any help
> would be appreciated.
> Thanks
> Andre
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/King-Oracle-Provider-not-available-on-Ubuntu-installation-tp5412286p5412286.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
