[mapguide-users] Constants for "MgPropertyDefinition" .
"GetPropertyType()" ?
Haris Kurtagic
haris at sl-king.com
Fri Aug 13 16:31:59 EDT 2010
constants as defined in c++
class MgFeaturePropertyType
PUBLISHED_API:
/// \brief
/// Type name for a data property definition. See
/// MgDataPropertyDefinition.
static const int DataProperty = 100;
/// \brief
/// Type name for an object property definition. See
/// MgObjectPropertyDefinition.
static const int ObjectProperty = 101;
/// \brief
/// Type name for a geometric property definition. See
/// MgGeometricPropertyDefinition.
static const int GeometricProperty = 102;
/// \brief
/// Type name for an association property definition.
/// \remarks
/// Currently there is no class for an association property
/// definition.
static const int AssociationProperty = 103;
/// Type name for a raster property definition. See
/// MgRasterPropertyDefinition.
static const int RasterProperty = 104;
Haris
On Fri, Aug 13, 2010 at 5:25 PM, Crispin_at_1Spatial
<crispin.hoult at 1spatial.com> wrote:
> Hi,
> Can anyone help me find the declarations for the datatypes from a
> "MgPropertyDefinition" . "GetPropertyType()" ?
> I have worked out 100 are data properties and 102 are data properties but
> would like some constants.
> In pure FDO they are called "Schema.PropertyType.PropertyType_DataProperty"
> It would make the code sample below better...
> - Thanks, Crispin
> MgPropertyDefinitionCollection colProperty = classDef.GetProperties();
> foreach (MgPropertyDefinition propThis in colProperty)
> // handle geometric and data properties only
> int typeofPropertyType = propThis.GetPropertyType();
> // where is the data type constant for this?
> if (102 == typeofPropertyType)
> MgGeometricPropertyDefinition geomProp =
> (MgGeometricPropertyDefinition)propThis;
> if (100 == typeofPropertyType)
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Constants-for-MgPropertyDefinition-GetPropertyType-tp5420442p5420442.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
