[mapguide-users] Problem with ODBC and Point Feature Display via
Lat Long
Warren Medernach
wmedernach at gmail.com
Fri Aug 13 17:50:10 EDT 2010
Hey Kori,
While this isn't an 'identical' test, I just tested this in MGE 2011 and can
confirm the same results.
The points DO NOT display under a different schema.
Warren M
On Fri, Aug 13, 2010 at 3:27 PM, Kori Maleski <kori.maleski at gmail.com>wrote:
> MapGuide 2.1.0.4283
> SQL Server 2005
> ODBC FDO 3.4
> I can create a Feature from the Lat Long columns of a table under the dbo
> schema, but if I use another schema the feature does not display in the map.
> Anybody else encounter this?
> Cheers,
> Kori Maleski
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100813/793b49b9/attachment.html
