[mapguide-users] Problem with ODBC and Point Feature Display via
Lat Long
Kori Maleski
kori.maleski at gmail.com
Fri Aug 13 17:56:41 EDT 2010
Thanks Warren!
So much for organizing by schema. Can't wait to get to switch to MS SQL
2008 for spatial.
Cheers,
Kori Maleski
On Fri, Aug 13, 2010 at 3:50 PM, Warren Medernach <wmedernach at gmail.com>wrote:
> Hey Kori,
> While this isn't an 'identical' test, I just tested this in MGE 2011 and
> can confirm the same results.
> The points DO NOT display under a different schema.
> Warren M
> On Fri, Aug 13, 2010 at 3:27 PM, Kori Maleski <kori.maleski at gmail.com>wrote:
>> MapGuide 2.1.0.4283
>> SQL Server 2005
>> ODBC FDO 3.4
>> I can create a Feature from the Lat Long columns of a table under the dbo
>> schema, but if I use another schema the feature does not display in the map.
>> Anybody else encounter this?
>> Cheers,
>> Kori Maleski
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100813/bcd82450/attachment.html
