[mapguide-users] Problem with ODBC and Point Feature Display via Lat Long
Dave Wilson dave.wilson at autodesk.com
Fri Aug 13 18:33:10 EDT 2010
When you say it doesn't work under another schema does your ODBC login have rights to the other schema and some of the system tables? I'm not sure exactly what the rights need to be. This is a question for the FDO users list.
I suspect it's a permissions issue.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kori Maleski
Sent: Friday, August 13, 2010 3:57 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Problem with ODBC and Point Feature Display via Lat Long
Thanks Warren!
So much for organizing by schema.  Can't wait to get to switch to MS SQL 2008 for spatial.
Cheers,
Kori Maleski
On Fri, Aug 13, 2010 at 3:50 PM, Warren Medernach <wmedernach at gmail.com<mailto:wmedernach at gmail.com>> wrote:
Hey Kori,
While this isn't an 'identical' test, I just tested this in MGE 2011 and can confirm the same results.
The points DO NOT display under a different schema.
Warren M
On Fri, Aug 13, 2010 at 3:27 PM, Kori Maleski <kori.maleski at gmail.com<mailto:kori.maleski at gmail.com>> wrote:
MapGuide 2.1.0.4283
SQL Server 2005
ODBC FDO 3.4
I can create a Feature from the Lat Long columns of a table under the dbo schema, but if I use another schema the feature does not display in the map.
Anybody else encounter this?
Cheers,
Kori Maleski
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100813/e5e6ad50/attachment.html
