[mapguide-users] Problem with ODBC and Point Feature Display via
Lat Long
Kori Maleski
kori.maleski at gmail.com
Fri Aug 13 18:51:17 EDT 2010
The ODBC SQL login has the same rights, and the schemas are in the same
database.
The work around is to create a dbo.view of the other schema.table.
Cheers,
Kori Maleski
On Fri, Aug 13, 2010 at 4:33 PM, Dave Wilson <dave.wilson at autodesk.com>wrote:
> When you say it doesn't work under another schema does your ODBC login
> have rights to the other schema and some of the system tables? I'm not sure
> exactly what the rights need to be. This is a question for the FDO users
> list.
> I suspect it's a permissions issue.
> Dave
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kori Maleski
> *Sent:* Friday, August 13, 2010 3:57 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Problem with ODBC and Point Feature
> Display via Lat Long
> Thanks Warren!
> So much for organizing by schema. Can't wait to get to switch to MS SQL
> 2008 for spatial.
> Cheers,
> Kori Maleski
> On Fri, Aug 13, 2010 at 3:50 PM, Warren Medernach <wmedernach at gmail.com>
> wrote:
> Hey Kori,
> While this isn't an 'identical' test, I just tested this in MGE 2011 and
> can confirm the same results.
> The points DO NOT display under a different schema.
> Warren M
> On Fri, Aug 13, 2010 at 3:27 PM, Kori Maleski <kori.maleski at gmail.com>
> wrote:
> MapGuide 2.1.0.4283
> SQL Server 2005
> ODBC FDO 3.4
> I can create a Feature from the Lat Long columns of a table under the dbo
> schema, but if I use another schema the feature does not display in the map.
> Anybody else encounter this?
> Cheers,
> Kori Maleski
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100813/a614ac5e/attachment.html
