[mapguide-users] Problem with ODBC and Point Feature Display via
Lat Long
Kori Maleski
kori.maleski at gmail.com
Fri Aug 13 19:07:05 EDT 2010
Ahh... If I set the SQL login to default to any other schema than dbo, then
ALL schemas will display features from Lat Long.
If it is defaulted to dbo, then only dbo will display.
Please correct me if anyone gets different results.
Cheers,
Kori Maleski
On Fri, Aug 13, 2010 at 4:51 PM, Kori Maleski <kori.maleski at gmail.com>wrote:
> The ODBC SQL login has the same rights, and the schemas are in the same
> database.
> The work around is to create a dbo.view of the other schema.table.
> Cheers,
> Kori Maleski
> On Fri, Aug 13, 2010 at 4:33 PM, Dave Wilson <dave.wilson at autodesk.com>wrote:
>> When you say it doesn't work under another schema does your ODBC login
>> have rights to the other schema and some of the system tables? I'm not sure
>> exactly what the rights need to be. This is a question for the FDO users
>> list.
>> I suspect it's a permissions issue.
>> Dave
>> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
>> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kori Maleski
>> *Sent:* Friday, August 13, 2010 3:57 PM
>> *To:* MapGuide Users Mail List
>> *Subject:* Re: [mapguide-users] Problem with ODBC and Point Feature
>> Display via Lat Long
>> Thanks Warren!
>> So much for organizing by schema. Can't wait to get to switch to MS SQL
>> 2008 for spatial.
>> Cheers,
>> Kori Maleski
>> On Fri, Aug 13, 2010 at 3:50 PM, Warren Medernach <wmedernach at gmail.com>
>> wrote:
>> Hey Kori,
>> While this isn't an 'identical' test, I just tested this in MGE 2011 and
>> can confirm the same results.
>> The points DO NOT display under a different schema.
>> Warren M
>> On Fri, Aug 13, 2010 at 3:27 PM, Kori Maleski <kori.maleski at gmail.com>
>> wrote:
>> MapGuide 2.1.0.4283
>> SQL Server 2005
>> ODBC FDO 3.4
>> I can create a Feature from the Lat Long columns of a table under the dbo
>> schema, but if I use another schema the feature does not display in the map.
>> Anybody else encounter this?
>> Cheers,
>> Kori Maleski
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100813/a6dcb4ab/attachment.html
