[mapguide-users] Refreshing a Layer
Zac Spitzer zac.spitzer at gmail.com
Tue Aug 17 00:19:20 EDT 2010
depending on the structure of the layers within your map, all layers
might be rendered into a single image, therefore refreshing
the map (frame) after toggling the layers is required
z
On 16 August 2010 01:54, finjai <jai at ipssi.com> wrote:
> Hi All,
>   I am trying to explore a possibility that is there a way by which one can
> refresh only a particular layer and not the entire set of layers.
> Example : suppose we have a set of 5 layers(namely Layers A,B,C,D,E) which
> constitutes the map. I have to refresh only "layer E". As of now i am trying
> to refresh the entire mapframe in order to this.
> Is there a possibility that this process quick by the refreshing only one
> particular.
> Thanks
> Jai
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Refreshing-a-Layer-tp5425458p5425458.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
