[mapguide-users] RE: featureService.SelectFeatures and memory consumption
Dave Wilson dave.wilson at autodesk.com
Wed Aug 18 11:38:50 EDT 2010
I have single layer from PostGis using the OSGeo.PostgreSQL 3.5 provider in MGE 2011 and I'm not seeing this behavior using the out of the box stuff. Are you using a Basic or Flexible layout?
There may be an issue with the provider specific to one of the API your are using.
When you mention panning and zooming below is there no custom code involved and again which Layout?
Regards,
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Vaidas Velutis
Sent: Wednesday, August 18, 2010 12:41 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] RE: featureService.SelectFeatures and memory consumption
We are using OSGeo.PostgreSQL (new). I have just found that i have bigger
problems than describet in first post. I have Map that contains layers from
OSGeo.PostgreSQL connection, i made some Pan and Zoom commands (for about 1
minute) and mgserver.exe process became from 50 MB to 300 MB of size.
I have same map build from SHP sources and it works good (process size is
not increasing while browsing that map). So i guess it is really FDO
provider or data provider related issue, mayby i am missing some
configuration stuff in postgreSQL database?
Does anyone uses PostGIS as datasource and do not have such kind of
problems?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Wednesday, August 18, 2010 8:52 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: featureService.SelectFeatures and memory
consumption
Is the provider OSGeo.PostGIS (old) or OSGeo.PostgreSQL (new)? The old
provider has many bugs and hasn't been maintained in a while.
- Jackie
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/featureService-SelectFeatures-and-mem
ory-consumption-tp5427455p5435161.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
