[mapguide-users] RE: Mapguide 2.2 Performance issue
Zac Spitzer zac.spitzer at gmail.com
Wed Aug 25 21:49:21 EDT 2010
In addition to Dave's requests. is there anything showing up in the error logs?
Also, If you have a look at the header of serverconfig.ini it does say
# MapGuide Server Configuration File
# The following configuration is based on a single CPU with a single core.
Ie, need to increase some parameters
There are hints here
http://sandbox.mapguide.com/index.php/MapGuide_Service_Tweaks
and some further documentation here
http://trac.osgeo.org/mapguide/wiki/ServerconfigWebConfigIni
z
On 26 August 2010 09:06, Homan, Thomas <thoman at co.gila.az.us> wrote:
> While this question is in the air…
> Are there specific documents floating out there (Autodesk/OSGeo generated)
> for tuning and capacity planning? The planning/deployment guides are
> decidedly lacking on details but a section on basic tuning would be quite
> helpful.
> I’ve seen emails stating that various files need to be modified (php.ini,
> *.config files, web admin and such) to maximize server use but have never
> found anything specific.
> Regards,
> Tom
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
> Sent: Wednesday, August 25, 2010 2:09 PM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] RE: Mapguide 2.2 Performance issue
> You will need to provide a lot more detail than "it doesn't work" to get a
> useful response :)
> What configuration are you using? .NET, APACHE etc..
> Are you using Basic or Flexible Web Layouts? What kind of data/providers are
> you using?
> Are you using raster imagery and if so what format?
> Yes the 64 connection limit has been removed, but other components including
> the Berkeley database and physical disk I/O for example will limit the
> number of concurrent connections?
> What is your hardware? How many CPUs/cores? Is everything running on the
> same box?
> What are your users doing at the time things lock up?
> Regards,
> Dave
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Devadoss, Bala
> (US)
> Sent: Wednesday, August 25, 2010 3:02 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Mapguide 2.2 Performance issue
> Hi,
> We just started testing 64 bit MGO 2.2 on windows 2008R2. When we load
> tested our site with 10 simultaneous users, the Mapguide service stops
> responding and we had to restart the service.
> I thought MGO2.2 is fixed to handle around 500 connections at the same time
> compared to 64 connections in MGO2.1.
> Please throw some ideas for the performance issue.
> Thanks,
> Bala
> This email is for the use of the intended recipient(s) only. If you have
> received this email in error, please notify the sender immediately and then
> delete it. If you are not the intended recipient, you must not keep, use,
> disclose, copy or distribute this email without the author's prior
> permission. We have taken precautions to minimize the risk of transmitting
> software viruses, but we advise you to carry out your own virus checks on
> any attachment to this message. We cannot accept liability for any loss or
> damage caused by software viruses. The information contained in this
> communication may be confidential and may be subject to the attorney-client
> privilege. If you are the intended recipient and you do not wish to receive
> similar electronic messages from us in the future then please respond to the
> sender to this effect.
> mapguide-users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
