[mapguide-users] RE: Mapguide 2.2 Performance issue
Jason Birch
jason at jasonbirch.com
Thu Aug 26 20:06:20 EDT 2010
It would be useful to try to narrow down what is causing the server to
become unresponsive. A couple things might help diagnose this:
- Output of "netstat -an" on all the web and mapguide servers.
- Output of the GetFdoCacheInfo call on the MapGuide server. Not sure if
this would still be available on the web tier when the server is
unresponsive though, or how you would access it otherwise.
- Any error messages from the MapGuide logs.
When the server fails, it just becomes unresponsive, right? How long have
you waited for it to time out? Have you tried lowering timeouts for FDO
cache and for server connections to see whether the service eventually comes
back? Or turning off FDO connection caching entirely as an experiment
(performance will suck, but at least it could help pinpoint the problem).
In general, joins are still not very performant. If possible, you'd be
better off reading the geometry and data from a view in the database if your
database supports spatial types.
Jason
On 26 August 2010 15:39, Devadoss, Bala (US) wrote:
> Hi Dave,
> Sorry for being vague in the first place. I am still a rookie to the
> Mapguide Open Source world.
> Please find the response below for your questions.
> What configuration are you using? .NET, APACHE etc..
> We are using .NET with IIS7 on Windows 2008 Server 64 bit
> Are you using Basic or Flexible Web Layouts? What kind of data/providers
> are you using?
> We are using Basic Layout embedded in an aspx page. We are using DWF and
> SDF files for the graphics with many of the SDF joined via the ODBC provider
> for dynamic access to tables in the database as the database is updated
> regularly. There is 1 SDF layer, 4 DWF layers, 13 themed SDF/ODBC joined
> layers, and 8 labeled SDF/ODBC point layers. The map xml is generated
> dynamically based on a user picked value from an aspx page.
> Are you using raster imagery and if so what format?
> No raster
> Yes the 64 connection limit has been removed, but other components
> including the Berkeley database and physical disk I/O for example will limit
> the number of concurrent connections?
> We have followed the criteria for optimized settings based on the
> webconfig/serverconfig document that Trevor published.
> What is your hardware? How many CPUs/cores? Is everything running on the
> same box?
> Two Virtual machines load balanced using F5 Load Balancer running MG and
> the .net code. Both machines have Intel Xeon CPU 2.6ghz 2 processor with
> 4 GB of RAM. SQL Server 2008 runs on a separate machine and currently the
> SDF files are stored on a separate machine although this was done recently
> to try and reduce disk IO on the server.
> What are your users doing at the time things lock up?
> We start at the initial screen and pick a value to load the map. Two or
> perhaps three may get the map loaded, all others will sit and wait until the
> server ultimately fails.
> Hope this will give you some information on what we did.
> I appreciate your help on this.
> Thanks,
> Bala
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Dave Wilson
> *Sent:* Wednesday, August 25, 2010 4:09 PM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] RE: Mapguide 2.2 Performance issue
> You will need to provide a lot more detail than "it doesn't work" to get a
> useful response :)
> are you using?
> same box?
> Regards,
> Dave
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Devadoss, Bala (US)
> *Sent:* Wednesday, August 25, 2010 3:02 PM
> *To:* mapguide-users at lists.osgeo.org
> *Subject:* [mapguide-users] Mapguide 2.2 Performance issue
> Hi,
> We just started testing 64 bit MGO 2.2 on windows 2008R2. When we load
> tested our site with 10 simultaneous users, the Mapguide service stops
> responding and we had to restart the service.
> I thought MGO2.2 is fixed to handle around 500 connections at the same time
> compared to 64 connections in MGO2.1.
> Please throw some ideas for the performance issue.
> Thanks,
> Bala
> This email is for the use of the intended recipient(s) only. If you have
> received this email in error, please notify the sender immediately and then
> delete it. If you are not the intended recipient, you must not keep, use,
> disclose, copy or distribute this email without the author's prior
> permission. We have taken precautions to minimize the risk of transmitting
> software viruses, but we advise you to carry out your own virus checks on
> any attachment to this message. We cannot accept liability for any loss or
> damage caused by software viruses. The information contained in this
> communication may be confidential and may be subject to the attorney-client
> privilege. If you are the intended recipient and you do not wish to receive
> similar electronic messages from us in the future then please respond to the
> sender to this effect.
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100826/c7b3f0ba/attachment.html
