[mapguide-users] Re: Broken Measure Tool
Steve G
steve.golden at morganhill.ca.gov
Mon Aug 30 13:10:43 EDT 2010
Thanks Jackie for the hint on looking in ajaxmappane.templ. I hadn't made
many changes to ajaxmappane.templ (I think I made one slight change to add
border lines around the data in the properties pane), however, when I used
the Compare tool in Notepad++ there is a bunch of code missing from the
ajaxmappane.templ on my production server when compared to the same file on
my test server. Kinda strange. Does the template file get updated in any
way when making any layout changes through Maestro? I don't think so, but
have to ask. Any other way that file could become corrupt?
I will lcopy my file from the test server over to production and see if this
resolves the problem (I will make a back-up copy just in case). I'll report
back just in case others are experiencing similar problems.
Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Broken-Measure-Tool-tp5466829p5479161.html
