[mapguide-users] Re: Simple search
Jackie Ng
jumpinjackie at gmail.com
Sun Dec 19 16:46:34 EST 2010
You say dbf so I assume shape file?
I believe SHP files truncate field names to 8 characters, so you might want
to check that the field name is actually "street_name" and not "street_n" or
something similar.
Secondly what is the filter you are trying to define? Here's some examples:
Equal to user input?
street_name = '$USER_VARIABLE'
Begins with user input?
street_name LIKE '$USER_VARIABLE%'
Ends with user input?
street_name LIKE '%$USER_VARIABLE'
$USER_VARIABLE is a special token that gets replaced with the actual input
value of the search command when you hit the search button.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Simple-search-tp5849425p5850231.html
