[mapguide-users] problem when using same code for
MapGuideEnterprise2009 with MapGuideEnterprise2010
ehsan
ehsan85 at yahoo.com
Mon Feb 1 02:25:49 EST 2010
i just changing my MapGuideEnterprise2009 to MapGuideEnterprise2010, i had
some trouble with my PHP code when use it in MapGuideEnterprise2010. Before
i use the MapGuideEnterprise2009, i use the MapGuide Open Source 2.0, the
code that i make is to search for NOLOT, select and zoom to selection in the
map, then the same code i use in MapGuideEnterprise2009 and it work well.
but when i use the MapGuideEnterprise2010 it seem does not work at all. when
i use the in Internet Explorer get this error
Webpage error details
Message: Object expected
Line: 56
Char: 1
Code: 0
URI:
http://localhost:8008/mapguide2010/phpsamples/Build/Search%20Query%202.php?SESSION=349b6ad6-f130-102c-8000-001b246a1fcd_en_7F0000010AF20AF10AF0&WEBLAYOUT=Library%3A%2F%2Fgis%2Flayoutmelaka.WebLayout&DWF=0&LOCALE=en&NOLOT=3475&LAYER=Lot
Tanah Melaka&DAERAH=03&MUKIM=Sungei Baru Ulu
when i check at my code at line 56, the code is:
<body class="AppFrame" onLoad="OnPageLoad()">
Is MapGuideEnterprise2010 can not use the same code from the
MapGuideEnterprise2009?
Thanks.
View this message in context: http://n2.nabble.com/problem-when-using-same-code-for-MapGuideEnterprise2009-with-MapGuideEnterprise2010-tp4492918p4492918.html
