[mapguide-users] problem when using same code for MapGuideEnterprise2009 with MapGuideEnterprise2010
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Feb 2 03:07:10 EST 2010
Most code will work just fine when upgrading, but if your code depends on
an undocumented feature or bug, it may not.
You need to give more information, perhaps post some of the script.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 01-02-2010 08:25, ehsan wrote:
> Hi,
> i just changing my MapGuideEnterprise2009 to MapGuideEnterprise2010, i had
> some trouble with my PHP code when use it in MapGuideEnterprise2010. Before
> i use the MapGuideEnterprise2009, i use the MapGuide Open Source 2.0, the
> code that i make is to search for NOLOT, select and zoom to selection in the
> map, then the same code i use in MapGuideEnterprise2009 and it work well.
> but when i use the MapGuideEnterprise2010 it seem does not work at all. when
> i use the in Internet Explorer get this error
> Webpage error details
> Message: Object expected
> Line: 56
> Char: 1
> Code: 0
> URI:
> http://localhost:8008/mapguide2010/phpsamples/Build/Search%20Query%202.php?SESSION=349b6ad6-f130-102c-8000-001b246a1fcd_en_7F0000010AF20AF10AF0&WEBLAYOUT=Library%3A%2F%2Fgis%2Flayoutmelaka.WebLayout&DWF=0&LOCALE=en&NOLOT=3475&LAYER=Lot
> Tanah Melaka&DAERAH=03&MUKIM=Sungei Baru Ulu
> when i check at my code at line 56, the code is:
> <body class="AppFrame" onLoad="OnPageLoad()">
> Is MapGuideEnterprise2010 can not use the same code from the
> MapGuideEnterprise2009?
> Thanks.
