[mapguide-users] Re: MapGuide with ASP.Net
kandiyateesh yateesh.kandi at patni.com
Thu Feb 18 04:58:00 EST 2010
Hi Kenneth,
I've copied the bin folder and the webconfig.ini file as mentioned in the
previous post. Also, I've referenced the same when the initialize function
is called. Now, I recieve an error saying,"The type initializer for
'OSGeo.MapGuide.MapGuideApiPINVOKE' threw an exception".
The following is my webconfig.ini file:
# MapGuide Web Configuration File
# WARNING: BE VERY CAREFUL WHEN MODIFYING THIS FILE AS IT COULD
#          ADVERSLY IMPACT SERVER PERFORMANCE
# COMMON VALIDATION INFORMATION
# (Unless otherwise noted under the property description)
# String Property                  Range of String Length   Reserved
Characters
# File Name                        0 <  Length <= 128       \/:*?"<>|
# Folder Name                      0 <  Length <= 128       \/:*?"<>|
# Log Parameters                   0 <= Length <= 1024
# Password                         0 <= Length <= 64        \t\r\n\v\f
# Path                             0 <  Length <= 255       *?"<>|
# Numeric Property                 Range of Numeric Value
# Port Number                      0 <= Value <= 65535
[GeneralProperties]
# G E N E R A L
# Property Name                    Description
# DefaultMessageLocale             ISO 639-1 name for the message locale
#                                       Length = 2
#                                       Example: en
#                                  or
#                                       Length = 5
#                                       Example: en-US
#                                  WARNING: if a 5 character locale is
specified
#                                           the first 2 characters must be
lower
#                                           case and the last 2 characters
must
#                                           be upper case.
# ResourcesPath                    Path where the localization resource
files are stored
# TcpIpMtu                         The TCP/IP maximum transmission unit
#                                       0 < Value <= 65535
# TempPath                         Path where the temporary files are stored
DefaultMessageLocale               = en
ResourcesPath                      =http:\\<ip
addr>\MapGuide\Web\www\mapagent\Resources
TcpIpMtu                           = 1460
TempPath                           =http:\\<ip addr>\MapGuide\Web\Temp\
[AdministrativeConnectionProperties]
# A D M I N I S T R A T I V E  C O N N E C T I O N
# Port                             The port to use for administration
operations
#                                  WARNING: If you change the port # here
you
#                                           must also change the
corresponding
#                                           port # for the server
configuration
#                                           file.
Port                               = 2810
[ClientConnectionProperties]
# C L I E N T  C O N N E C T I O N
# Port                             The port to use for client operations
you
corresponding
configuration
#                                           file.
Port                               = 2811
[SiteConnectionProperties]
# S I T E  C O N N E C T I O N
# IpAddress                        The IP address of the site server
#                                       0 < Length <= 255
# Port                             The port to use for site operations
you
corresponding
configuration
#                                           file.
IpAddress                          =<ip addr>
Port                               = 2812
[AgentProperties]
# M A P  A G E N T
# DebugPause                       Number of seconds the agent pauses before
#                                  each request, for debugging purpose
#                                       0 <= Value <= 86400
# DisableAuthoring                 Disables Authoring HTTP requests
#                                       0 = false and 1 = true
# DisableWfs                       Disables OGC Wfs HTTP requests
# DisableWms                       Disables OGC Wms HTTP requests
DebugPause                         = 0
DisableAuthoring                   = 0
DisableWfs                         = 0
DisableWms                         = 0
[OgcProperties]
# O G C  S E T T I N G S
# WfsPassword                      Password to be used for credentials in
WFS
#                                  requests
# WmsPassword                      Password to be used for credentials in
WMS
#                                  requests
WfsPassword                        = wfs
WmsPassword                        = wms
[WebApplicationProperties]
# W E B   A P P L I C A T I O N   S E T T I N G S
# TemplateRootFolder               The root folder containing the viewer
#                                  templates
# WidgetInfoFolder                 The folder containing widget info files
# ContainerInfoFolder              The folder containing container info
files
TemplateRootFolder                 =http:\\<ip
addr>\MapGuide\Web\www\fusion\templates\mapguide
WidgetInfoFolder                   =http:\\<ip
addr>\MapGuide\Web\www\fusion\widgets\widgetinfo
ContainerInfoFolder                =http:\\<ip
addr>\MapGuide\Web\www\fusion\containerinfo
Pls help me out in sorting out this issue.
Regards,
Yateesh
View this message in context: http://n2.nabble.com/MapGuide-with-ASP-Net-tp4333250p4590881.html
