[mapguide-users] Re: MapGuide with ASP.Net
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Feb 18 05:42:42 EST 2010
This usually means that the MapGuide binary dll fails to load.
Check that the MapGuide binaries are in the bin folder where your app
runs from.
If they are, you best bet is to run ProcessMonitor to see what dll's it
attempts to load.
Also, the exception should have some "innerexception" or other property
with more detailed info.
http://n2.nabble.com/MapGuideApiPINVOKE-tp4478803p4506237.html
To use ProcessMonitor, do this:
1) Install ProcessMonitor
http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx
2) run "IISRESET" from the commandline
3) Start process monitor
4) Start the application, and get the error
5) Examine the w3p process and see what files it attempts to load.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 18-02-2010 10:58, kandiyateesh wrote:
> Hi Kenneth,
> I've copied the bin folder and the webconfig.ini file as mentioned in the
> previous post. Also, I've referenced the same when the initialize function
> is called. Now, I recieve an error saying,"The type initializer for
> 'OSGeo.MapGuide.MapGuideApiPINVOKE' threw an exception".
> The following is my webconfig.ini file:
> # MapGuide Web Configuration File
> # WARNING: BE VERY CAREFUL WHEN MODIFYING THIS FILE AS IT COULD
> #          ADVERSLY IMPACT SERVER PERFORMANCE
> # COMMON VALIDATION INFORMATION
> # (Unless otherwise noted under the property description)
> # String Property                  Range of String Length   Reserved
> Characters
> # File Name                        0<   Length<= 128       \/:*?"<>|
> # Folder Name                      0<   Length<= 128       \/:*?"<>|
> # Log Parameters                   0<= Length<= 1024
> # Password                         0<= Length<= 64        \t\r\n\v\f
> # Path                             0<   Length<= 255       *?"<>|
> # Numeric Property                 Range of Numeric Value
> # Port Number                      0<= Value<= 65535
> [GeneralProperties]
> # G E N E R A L
> # Property Name                    Description
> # DefaultMessageLocale             ISO 639-1 name for the message locale
> #                                       Length = 2
> #                                       Example: en
> #                                  or
> #                                       Length = 5
> #                                       Example: en-US
> #                                  WARNING: if a 5 character locale is
> specified
> #                                           the first 2 characters must be
> lower
> #                                           case and the last 2 characters
> must
> #                                           be upper case.
> # ResourcesPath                    Path where the localization resource
> files are stored
> # TcpIpMtu                         The TCP/IP maximum transmission unit
> #                                       0<  Value<= 65535
> # TempPath                         Path where the temporary files are stored
> DefaultMessageLocale               = en
> ResourcesPath                      =http:\\<ip
> addr>\MapGuide\Web\www\mapagent\Resources
> TcpIpMtu                           = 1460
> TempPath                           =http:\\<ip addr>\MapGuide\Web\Temp\
> [AdministrativeConnectionProperties]
> # A D M I N I S T R A T I V E  C O N N E C T I O N
> # Port                             The port to use for administration
> operations
> #                                  WARNING: If you change the port # here
> you
> #                                           must also change the
> corresponding
> #                                           port # for the server
> configuration
> #                                           file.
> Port                               = 2810
> [ClientConnectionProperties]
> # C L I E N T  C O N N E C T I O N
> # Port                             The port to use for client operations
> you
> corresponding
> configuration
> #                                           file.
> Port                               = 2811
> [SiteConnectionProperties]
> # S I T E  C O N N E C T I O N
> # IpAddress                        The IP address of the site server
> #                                       0<  Length<= 255
> # Port                             The port to use for site operations
> you
> corresponding
> configuration
> #                                           file.
> IpAddress                          =<ip addr>
> Port                               = 2812
> [AgentProperties]
> # M A P  A G E N T
> # DebugPause                       Number of seconds the agent pauses before
> #                                  each request, for debugging purpose
> #                                       0<= Value<= 86400
> # DisableAuthoring                 Disables Authoring HTTP requests
> #                                       0 = false and 1 = true
> # DisableWfs                       Disables OGC Wfs HTTP requests
> # DisableWms                       Disables OGC Wms HTTP requests
> DebugPause                         = 0
> DisableAuthoring                   = 0
> DisableWfs                         = 0
> DisableWms                         = 0
> [OgcProperties]
> # O G C  S E T T I N G S
> # WfsPassword                      Password to be used for credentials in
> WFS
> #                                  requests
> # WmsPassword                      Password to be used for credentials in
> WMS
> #                                  requests
> WfsPassword                        = wfs
> WmsPassword                        = wms
> [WebApplicationProperties]
> # W E B   A P P L I C A T I O N   S E T T I N G S
> # TemplateRootFolder               The root folder containing the viewer
> #                                  templates
> # WidgetInfoFolder                 The folder containing widget info files
> # ContainerInfoFolder              The folder containing container info
> files
> TemplateRootFolder                 =http:\\<ip
> addr>\MapGuide\Web\www\fusion\templates\mapguide
> WidgetInfoFolder                   =http:\\<ip
> addr>\MapGuide\Web\www\fusion\widgets\widgetinfo
> ContainerInfoFolder                =http:\\<ip
> addr>\MapGuide\Web\www\fusion\containerinfo
> Pls help me out in sorting out this issue.
> Regards,
> Yateesh
