[mapguide-users] Re: Problem with Studio 2010 +Flexible layouts
Error
Mark Pendergraft
markp at Meadgilman.com
Mon Feb 22 13:06:27 EST 2010
The coordinate system issue can be resolved by setting the projection of your
map in the MapGroup element of the ApplicationDefinition. See the link for
an example.
http://n2.nabble.com/Scale-and-Unit-problems-with-state-plane-coord-sys-td4499208.html#a4499208
If you are having issues with Fusion, you could download a copy of the trunk
using SVN, which is described here:
http://n2.nabble.com/how-to-download-the-latest-SVN-version-td3997693.html
And lastly, you could open up Fusion.js, scroll down to line 1196 and see if
you can figure out what is breaking the javascript.
Good luck, let us know what you come up with.
-Mark P.
View this message in context: http://n2.nabble.com/Problem-with-Studio-2010-Flexible-layouts-Error-tp4596619p4613936.html
