[mapguide-users] Re: Problem with Studio 2010 +Flexible layouts Error
padmini godavarthi godavarthi.padmini at gmail.com
Tue Feb 23 00:01:28 EST 2010
Hi mark,
Thanku very much for your reply........
can u plz clarify some of my doubts....
1) After clicking "show in browser" i got a map posted previously.After
Zooming the map may times it comes to original data .I have set the
coordinate system in my map definition is
UTM83-11 (UTM with NAD83 datum, Zone 11, Meter; Central Meridian 117d W)
which is correct to my shape file.
and my application defintion is
<ApplicationDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="ApplicationDefinition-1.0.0.xsd">
* MapSet
* Contains the map(s) you want available to your
* application.
 <MapSet>
     <MapGroup id="layer">
       <Map>
         <Type>MapGuide</Type>
         <SingleTile>true</SingleTile>
         <Extension>
           <ResourceId>Library://state/layer.MapDefinition</ResourceId>
           <SelectionAsOverlay>true</SelectionAsOverlay>
           <SelectionColor>0x0000FFA0</SelectionColor>
         </Extension>
       </Map>
       <Extension />
     </MapGroup>
  </MapSet>
* WidgetSet
* Contains the widgets you want available to your
* application.
  <WidgetSet xsi:type="WidgetSetType">
* ContextMenu (Tasks)
* Menu available to the Task Pane
    <Container xsi:type="UiItemContainerType">
      <Name>TaskContextMenu</Name>
      <Type>ContextMenu</Type>
      <Item xsi:type="WidgetItemType">
        <Function>Widget</Function>
        <Widget>menuMeasure</Widget>
      </Item>
        <Widget>menuBuffer</Widget>
      </Item>
    </Container>
* ContextMenu (Map)
* Menu available to the Map on right-click
      <Name>MapContextMenu</Name>
        <Widget>menuRefreshMap</Widget>
      </Item>
      <Item xsi:type="SeparatorItemType">
        <Function>Separator</Function>
      </Item>
        <Widget>menuPan</Widget>
      </Item>
        <Widget>menuZoomInRectangle</Widget>
      </Item>
      </Item>
        <Widget>menuZoomInFixed</Widget>
      </Item>
        <Widget>menuZoomOutFixed</Widget>
      </Item>
      </Item>
      <Item xsi:type="FlyoutItemType">
        <Function>Flyout</Function>
        <Label>Zoom</Label>
        <Tooltip>Open the zoom menu</Tooltip>
        <ImageUrl/>
        <ImageClass/>
          <Widget>menuInitialMapView</Widget>
        </Item>
          <Widget>menuPreviousView</Widget>
        </Item>
          <Widget>menuNextView</Widget>
        </Item>
          <Widget>menuInitialMapScaleAndCenter</Widget>
        </Item>
          <Widget>menuZoomSelection</Widget>
        </Item>
      </Item>
      </Item>
        <Widget>menuSelect</Widget>
      </Item>
        <Widget>menuClearSelection</Widget>
      </Item>
        <Label>Select More</Label>
        <Tooltip>Open the select menu</Tooltip>
        <ImageUrl/>
        <ImageClass/>
          <Widget>menuSelectRadius</Widget>
        </Item>
          <Widget>menuSelectPolygon</Widget>
        </Item>
          <Widget>menuSelectWithin</Widget>
        </Item>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
        <Widget>menuViewOptions</Widget>
      </Item>
      </Item>
        <Widget>menuHelp</Widget>
      </Item>
        <Widget>menuAbout</Widget>
      </Item>
    </Container>
* Toolbar (Primary)
      <Name>Toolbar</Name>
      <Type>Toolbar</Type>
        <Widget>toolbarHelp</Widget>
      </Item>
        <Widget>toolbarAbout</Widget>
      </Item>
        <Widget>toolbarViewOptions</Widget>
      </Item>
        <Widget>GetPrintablePage</Widget>
      </Item>
      </Item>
        <Widget>toolbarSelectRadius</Widget>
      </Item>
        <Widget>toolbarSelectPolygon</Widget>
      </Item>
        <Widget>toolbarSelectWithin</Widget>
      </Item>
        <Widget>toolbarClearSelection</Widget>
      </Item>
      </Item>
        <Widget>toolbarMeasure</Widget>
      </Item>
        <Widget>toolbarBuffer</Widget>
      </Item>
      </Item>
        <Widget>toolbarRefreshMap</Widget>
      </Item>
    </Container>
* Toolbar (Secondary)
      <Name>ToolbarSecondary</Name>
        <Widget>Select</Widget>
      </Item>
        <Widget>Pan</Widget>
      </Item>
      </Item>
        <Widget>ZoomInRectangle</Widget>
      </Item>
        <Widget>ZoomInFixed</Widget>
      </Item>
        <Widget>ZoomOutFixed</Widget>
      </Item>
      </Item>
        <Widget>toolbarSecondaryInitialMapView</Widget>
      </Item>
        <Widget>toolbarSecondaryPreviousView</Widget>
      </Item>
        <Widget>toolbarSecondaryNextView</Widget>
      </Item>
      </Item>
        <Widget>toolbarSecondaryZoomSelection</Widget>
      </Item>
    </Container>
* File Menu
* File Menu at the top of the application.
      <Name>FileMenu</Name>
          <Widget>MapMenu</Widget>
        </Item>
        <Label>View</Label>
        <Tooltip/>
        <ImageUrl/>
        <ImageClass/>
          <Widget>showOverviewMap</Widget>
        </Item>
      </Item>
        <Label>Tasks</Label>
        <Tooltip/>
        <ImageUrl/>
        <ImageClass/>
          <Widget>menuPlaceholder</Widget>
        </Item>
      </Item>
    </Container>
* Statusbar (Status Bar)
      <Name>Statusbar</Name>
      <Type>Splitterbar</Type>
        <Widget>StatusCoords</Widget>
      </Item>
        <Widget>StatusSelection</Widget>
      </Item>
        <Widget>StatusScale</Widget>
      </Item>
        <Widget>StatusViewSize</Widget>
      </Item>
    </Container>
* Placeholder Widget
    <Widget xsi:type="WidgetType">
      <Name>menuPlaceholder</Name>
      <Type>InvokeScript</Type>
      <StatusItem/>
      <Extension>
        <Script>return true</Script>
      </Extension>
      <ImageUrl/>
      <ImageClass/>
      <Tooltip/>
      <Label>menu item</Label>
      <Disabled/>
    </Widget>
<!-- MAP -->
    <MapWidget xsi:type="WidgetType">
      <Name>Map</Name>
      <Type>Map</Type>
      <StatusItem>The map.</StatusItem>
      <Extension xsi:type="CustomContentType">
        <MenuContainer>MapContextMenu</MenuContainer>
        <!--Scales>100000,50000,25000,12500,8000,4000</Scales-->
      </Extension>
      <MapId>sheboygan</MapId>
    </MapWidget>
* Context Menu - Widgets
* Widgets belonging to the map context menu
<!-- CONTEXT MENU PAN -->
    <Widget xsi:type="UiWidgetType">
      <Name>menuPan</Name>
      <Type>Pan</Type>
      <StatusItem>Drag the map to view areas out of range.</StatusItem>
      <ImageUrl>images/icons.png</ImageUrl>
      <ImageClass>pan</ImageClass>
      <Tooltip>Pan mode</Tooltip>
      <Label>Pan</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU ZOOM RECTANGLE -->
      <Name>menuZoomInRectangle</Name>
      <Type>Zoom</Type>
      <StatusItem>Zoom in on an area.</StatusItem>
        <Tolerance>5</Tolerance>
        <Factor>2</Factor>
      </Extension>
      <ImageClass>zoom-in</ImageClass>
      <Tooltip>Zoom In</Tooltip>
      <Label>Zoom Rectangle</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU ZOOM FIXED (IN) -->
      <Name>menuZoomInFixed</Name>
      <Type>ZoomOnClick</Type>
      <StatusItem>Zoom in by a preset increment.</StatusItem>
        <Factor>2</Factor>
      </Extension>
      <ImageClass>zoom-in-fixed</ImageClass>
      <Label>Zoom In</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU REFRESH MAP -->
      <Name>menuRefreshMap</Name>
      <Type>RefreshMap</Type>
      <StatusItem>Refreshes the map image.</StatusItem>
      <ImageClass>view-refresh</ImageClass>
      <Tooltip>Refresh map and reload all layers, keeping the current center
point and scale.</Tooltip>
      <Label>Refresh Map</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU ZOOM FIXED (OUT) -->
      <Name>menuZoomOutFixed</Name>
      <StatusItem>Zoom out by a preset increment</StatusItem>
        <Factor>0.5</Factor>
      </Extension>
      <ImageClass>zoom-out-fixed</ImageClass>
      <Tooltip>Zoom Out</Tooltip>
      <Label>Zoom Out</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU INITIAL MAP VIEW -->
      <Name>menuInitialMapView</Name>
      <Type>InitialMapView</Type>
      <StatusItem>Fit the extents of the map to the window</StatusItem>
        <ViewType>extent</ViewType>
      </Extension>
      <ImageClass>zoom-full</ImageClass>
      <Tooltip>Initial Map View</Tooltip>
      <Label>Initial Map View</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU PREVIOUS VIEW -->
      <Name>menuPreviousView</Name>
      <Type>ExtentHistory</Type>
      <StatusItem>Go to previous view.</StatusItem>
        <Direction>previous</Direction>
      </Extension>
      <ImageClass>view-back</ImageClass>
      <Tooltip>Previous View</Tooltip>
      <Label>View Previous</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU NEXT VIEW -->
      <Name>menuNextView</Name>
      <StatusItem>Go to next view.</StatusItem>
        <Direction>next</Direction>
      </Extension>
      <ImageClass>view-forward</ImageClass>
      <Tooltip>Next View</Tooltip>
      <Label>View Next</Label>
      <Disabled/>
    </Widget>
      <Name>menuInitialMapScaleAndCenter</Name>
      <StatusItem>Zoom to initial map center and scale.</StatusItem>
        <ViewType>center</ViewType>
      </Extension>
      <Tooltip>Initial Map Center and Scale</Tooltip>
      <Label>Initial Center and Scale</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU ZOOM SELECTION -->
      <Name>menuZoomSelection</Name>
      <Type>ZoomToSelection</Type>
      <StatusItem>Zoom to the extents of the current selection.</StatusItem>
      <ImageClass>select-zoom</ImageClass>
      <Tooltip>Zoom to selection.</Tooltip>
      <Label>Zoom Selection</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU SELECT -->
      <Name>menuSelect</Name>
      <Type>Select</Type>
      <StatusItem>Select features by clicking and dragging.</StatusItem>
      <ImageClass>select-features</ImageClass>
      <Tooltip>Select mode</Tooltip>
      <Label>Select mode</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU CLEAR SELECTION -->
      <Name>menuClearSelection</Name>
      <Type>ClearSelection</Type>
      <StatusItem>Clears the current selection.</StatusItem>
      <ImageClass>select-clear</ImageClass>
      <Tooltip/>
      <Label>Clear Selection</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU SELECT RADIUS -->
      <Name>menuSelectRadius</Name>
      <Type>SelectRadius</Type>
      <StatusItem>Click and drag to select all features inside a
circle.</StatusItem>
      <ImageClass>select-radius</ImageClass>
      <Tooltip>Select Radius</Tooltip>
      <Label>Select Radius</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU SELECT POLYGON -->
      <Name>menuSelectPolygon</Name>
      <Type>SelectPolygon</Type>
      <StatusItem>Create a polygon and select all features that fall
within.</StatusItem>
      <ImageClass>select-polygon</ImageClass>
      <Tooltip>Select Polygon</Tooltip>
      <Label>Select Polygon</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU SELECT WITHIN -->
      <Name>menuSelectWithin</Name>
      <Type>SelectWithin</Type>
      <StatusItem>Select all features that fall within the currently
selected area.</StatusItem>
      <ImageClass>select-within</ImageClass>
      <Tooltip>Select Within</Tooltip>
      <Label>Select Within</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU BUFFER -->
      <Name>menuBuffer</Name>
      <Type>BufferPanel</Type>
      <StatusItem>Create buffers around the selected features</StatusItem>
      <ImageClass>buffer</ImageClass>
      <Tooltip>Buffer</Tooltip>
      <Label>Buffer</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU  VIEW OPTIONS -->
      <Name>menuViewOptions</Name>
      <Type>ViewOptions</Type>
      <StatusItem>Switch between Imperial and Metric units</StatusItem>
        <DisplayUnits>degrees</DisplayUnits>
      </Extension>
      <ImageClass>view-options</ImageClass>
      <Tooltip/>
      <Label>View Options</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU HELP -->
      <Name>menuHelp</Name>
      <Type>Help</Type>
      <StatusItem/>
      <ImageClass>help</ImageClass>
      <Tooltip/>
      <Label>Help</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU ABOUT -->
      <Name>menuAbout</Name>
      <Type>About</Type>
      <StatusItem/>
      <ImageUrl/>
      <ImageClass/>
      <Tooltip/>
      <Label>About</Label>
      <Disabled/>
    </Widget>
<!-- CONTEXT MENU MEASURE -->
      <Name>menuMeasure</Name>
      <Type>Measure</Type>
      <StatusItem>Measure distances on the map.</StatusItem>
        <Type>both</Type>
        <MeasureTooltipContainer>MeasureResult</MeasureTooltipContainer>
        <MeasureTooltipType>dynamic</MeasureTooltipType>
        <DistancePrecision>0</DistancePrecision>
        <AreaPrecision>0</AreaPrecision>
        <Units>meters</Units>
        <Target>TaskPane</Target>
      </Extension>
      <ImageClass>measure</ImageClass>
      <Label>Measure</Label>
      <Disabled/>
    </Widget>
<!-- FILE MENU LAUNCH NAVIGATOR -->
      <Name>showOverviewMap</Name>
      <StatusItem/>
      <Extension>
        <Script>showOverviewMap()</Script>
      </Extension>
      <ImageUrl>images/icons/iconNavigator.png</ImageUrl>
      <ImageClass/>
      <Tooltip>Launch Overview Map</Tooltip>
      <Label>Launch Overview Map</Label>
      <Disabled/>
    </Widget>
* Toolbar - Widgets
* Widgets belonging to the main toolbar
<!-- TOOLBAR BUFFER -->
      <Name>toolbarBuffer</Name>
      <Extension>
      </Extension>
      <Disabled/>
    </Widget>
<!-- TOOLBAR REFRESH MAP -->
      <Name>toolbarRefreshMap</Name>
      <Disabled/>
    </Widget>
<!-- TOOLBAR MEASURE -->
      <Name>toolbarMeasure</Name>
        <Type>both</Type>
      </Extension>
      <Tooltip>Measure</Tooltip>
      <Disabled/>
    </Widget>
<!-- TOOLBAR VIEW OPTIONS -->
      <Name>toolbarViewOptions</Name>
        <DisplayUnits>meters</DisplayUnits>
      </Extension>
      <Tooltip/>
      <Disabled/>
    </Widget>
<!-- TOOLBAR HELP -->
      <Name>toolbarHelp</Name>
      <Type>Help</Type>
      <StatusItem/>
      <Tooltip/>
      <Label></Label>
      <Disabled/>
    </Widget>
<!-- TOOLBAR ABOUT -->
      <Name>toolbarAbout</Name>
      <Type>About</Type>
      <StatusItem/>
      <ImageUrl/>
      <ImageClass/>
      <Tooltip/>
      <Disabled/>
    </Widget>
<!-- TOOLBAR CLEAR SELECTION -->
      <Name>toolbarClearSelection</Name>
      <Tooltip/>
      <Label></Label>
      <Disabled/>
    </Widget>
<!-- TOOLBAR SELECT RADIUS -->
      <Name>toolbarSelectRadius</Name>
      <Label></Label>
      <Disabled/>
    </Widget>
<!-- TOOLBAR SELECT POLYGON -->
      <Name>toolbarSelectPolygon</Name>
      <Label></Label>
      <Disabled/>
    </Widget>
* Secondary toolbar - Widgets
* Widgets belonging to the secondary toolbar
<!-- SECONDARY TOOLBAR INITIAL MAP VIEW -->
      <Name>toolbarSecondaryInitialMapView</Name>
      </Extension>
      <Label/>
      <Disabled/>
    </Widget>
<!-- SECONDARY TOOLBAR PREVIOUS VIEW-->
      <Name>toolbarSecondaryPreviousView</Name>
      </Extension>
      <Label/>
      <Disabled/>
    </Widget>
<!-- SECONDARY TOOLBAR NEXT VIEW -->
      <Name>toolbarSecondaryNextView</Name>
      </Extension>
      <Label/>
      <Disabled/>
    </Widget>
<!-- SECONDARY TOOLBAR ZOOM SELECTION -->
      <Name>toolbarSecondaryZoomSelection</Name>
      <Label/>
      <Disabled/>
    </Widget>
<!-- SECONDARY TOOLBAR SELECT WITHIN -->
      <Name>toolbarSelectWithin</Name>
      <ImageUrl>images/icons/select-features.png</ImageUrl>
      <Extension>
      </Extension>
      <ImageClass/>
      <Label></Label>
      <Disabled/>
    </Widget>
* Status Bar - Widgets
* Widgets belonging to the status bar
<!-- STATUS POSITION -->
      <Name>StatusCoords</Name>
      <Type>CursorPosition</Type>
      <StatusItem/>
        <Template>X: {x} {units}, Y: {y} {units}</Template>
        <Precision>4</Precision>
        <EmptyText>&amp;nbsp;</EmptyText>
      </Extension>
    </Widget>
<!-- STATUS SELECTION INFO -->
      <Name>StatusSelection</Name>
      <Type>SelectionInfo</Type>
      <StatusItem/>
      <Extension>
          <EmptyText>No selection.</EmptyText>
     </Extension>
    </Widget>
<!-- STATUS SCALE -->
      <Name>StatusScale</Name>
      <Type>EditableScale</Type>
      <StatusItem/>
    </Widget>
<!-- STATUS VIEWSIZE -->
      <Name>StatusViewSize</Name>
      <Type>ViewSize</Type>
      <StatusItem/>
        <Template>{w} x {h} ({units})</Template>
        <Precision>2</Precision>
      </Extension>
    </Widget>
* Panels - Widgets
<!-- LEGEND -->
      <Name>Legend</Name>
      <Type>Legend</Type>
      <StatusItem/>
    </Widget>
<!-- SELECTION -->
      <Name>SelectionPanel</Name>
      <Type>SelectionPanel</Type>
      <StatusItem/>
    </Widget>
<!-- TASKS -->
      <Name>TaskPane</Name>
      <Type>TaskPane</Type>
      <StatusItem/>
      <Extension>
        <MenuContainer>TaskContextMenu</MenuContainer>
      </Extension>
    </Widget>
* Misc - Widgets
<!-- INMAP NAVIGATOR -->
      <Name>Navigator</Name>
      <Type>Navigator</Type>
      </Extension>
    </Widget>
<!-- ZOOM IN RECTANGLE -->
      <Name>ZoomInRectangle</Name>
      <Type>Zoom</Type>
        <Factor>2</Factor>
      </Extension>
      <Tooltip>Zoom in to a rectangular region.</Tooltip>
      <Label/>
      <Disabled/>
    </Widget>
<!-- ZOOM ON CLICK (IN) -->
      <Name>ZoomInFixed</Name>
        <Factor>4</Factor>
      </Extension>
      <Tooltip>Zoom in by a fixed factor.</Tooltip>
      <Label/>
      <Disabled/>
    </Widget>
<!-- ZOOM ON CLICK (OUT) -->
      <Name>ZoomOutFixed</Name>
      </Extension>
      <Tooltip>Zoom Out by a fixed factor</Tooltip>
      <Label/>
      <Disabled/>
    </Widget>
<!-- SELECT -->
      <Name>Select</Name>
      <Type>Select</Type>
      <Label/>
      <Disabled/>
    </Widget>
<!-- MAPMENU -->
    <Widget>
      <Name>MapMenu</Name>
      <Type>MapMenu</Type>
      <StatusItem/>
      <Extension/>
      <ImageUrl/>
      <ImageClass/>
      <Tooltip/>
      <Label>Maps</Label>
      <Disabled/>
    </Widget>
<!-- OVERVIEW MAP -->
      <Name>OverviewMap</Name>
      <Type>OverviewMap</Type>
      <Description/>
      </Extension>
    </Widget>
<!-- PRINT -->
      <Name>GetPrintablePage</Name>
      <Type>Print</Type>
      <StatusItem>Get printer-friendly page.</StatusItem>
        <ShowPrintUI>true</ShowPrintUI>
        <ShowTitle>true</ShowTitle>
        <PageTitle>Some Title</PageTitle>
        <ShowLegend>true</ShowLegend>
        <ShowNorthArrow>true</ShowNorthArrow>
        <ImageBaseUrl>images/</ImageBaseUrl>
      </Extension>
      <ImageClass>file-print</ImageClass>
      <Tooltip>Get printable page.</Tooltip>
      <Label></Label>
      <Disabled/>
    </Widget>
<!-- PAN -->
      <Name>Pan</Name>
      <Type>Pan</Type>
      <Label/>
      <Disabled/>
    </Widget>
      <Name>Scalebar</Name>
      <Type>ScalebarDual</Type>
    </Widget>
      <Name>MapTip</Name>
      <Type>Maptip</Type>
      <Extension>
        <Label>Map Tips</Label>
        <Delay>350</Delay>
        <Layer>Parcels</Layer>
      </Extension>
    </Widget>
  </WidgetSet>
  <Extension/>
</ApplicationDefinition>
is there any modifications required??????????????
2)And i have create one flexible layout by taking slate flexible layout as a
sampe.but it didn't apper in MG studio..Is there any chages required to
display it in MG studio.I have refresh MG studio but of no use.............
Regards,
Padmini.
View this message in context: http://n2.nabble.com/Problem-with-Studio-2010-Flexible-layouts-Error-tp4596619p4616964.html
