[mapguide-users] Re: Problem with Studio 2010 +Flexible layouts
Error
Mark Pendergraft
markp at Meadgilman.com
Tue Feb 23 11:29:40 EST 2010
As was pointed out in the link i posted, you need to change the projection of
your map in the Application Definition. Under the Extension element, you
need to add a ProjectionCode and a ProjectionDef node.
I believe the ProjectionCode you want is:
EPSG:26911
the ProjectionDef would be:
+proj=utm +zone=11 +ellps=GRS80 +datum=NAD83 +units=m +no_defs
So your map definition should be something like the following:
<MapSet>
<MapGroup id="layer">
<Map>
<Type>MapGuide</Type>
<SingleTile>true</SingleTile>
<Extension>
<ProjectionCode>EPSG:26911</ProjectionCode>
<ProjectionDef>+proj=utm +zone=11 +ellps=GRS80 +datum=NAD83
+units=m +no_defs</ProjectionDef>
<ResourceId>Library://MFS/Maps/MGA.MapDefinition</ResourceId>
<ResourceId>Library://state/layer.MapDefinition</ResourceId>
<SelectionAsOverlay>true</SelectionAsOverlay>
<SelectionColor>0x0000FFA0</SelectionColor>
</Extension>
</Map>
<Extension />
</MapGroup>
</MapSet>
-Mark
View this message in context: http://n2.nabble.com/Problem-with-Studio-2010-Flexible-layouts-Error-tp4596619p4619931.html
