[mapguide-users] Re: Problem with Studio 2010 +Flexible layouts
Error
padmini godavarthi
godavarthi.padmini at gmail.com
Tue Feb 23 23:33:48 EST 2010
Hi Mark,
First of all thank you very much for your patience and help.
But in my mapdefinition the projection system is
handled......................
<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="MapDefinition-1.0.0.xsd">
<Name>New Map</Name>
<CoordinateSystem>PROJCS["NAD_1983_UTM_Zone_11N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-117.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]</CoordinateSystem>
<Extents>
<MinX>271673.8130436262</MinX>
<MaxX>512056.71341944818</MaxX>
<MinY>3750970.4455238734</MinY>
<MaxY>3858924.9056628617</MaxY>
</Extents>
<BackgroundColor>ffffffff</BackgroundColor>
<MapLayer>
<Name>layer1</Name>
<ResourceId>Library://flexsample1/layer1.LayerDefinition</ResourceId>
<Selectable>true</Selectable>
<ShowInLegend>true</ShowInLegend>
<LegendLabel>layer1</LegendLabel>
<ExpandInLegend>true</ExpandInLegend>
<Visible>true</Visible>
<Group></Group>
</MapLayer>
</MapDefinition>
where the application definition.xml(iam using slate temple .is it in slate
templete folder??) is exactly located to modify the projection system ..
Regards,
Padmini G.
View this message in context: http://n2.nabble.com/Problem-with-Studio-2010-Flexible-layouts-Error-tp4596619p4623694.html
