[mapguide-users] Re: FDO/SQL formating expressions
icycool at inbox.com icycool at inbox.com
Tue Feb 23 21:10:18 EST 2010
Hey Jackie
I have bit of problem with that. I know the Services API is in the mapagent
folder of the webextenstion installation. I could actually load the plain
HTML page. The problem is I'm unable to load the  mapagent.fcgi in the web
browser!
I point to it using this URL:
http://localhost:8008/mapguide/mapagent/mapagent.fcgi. It then prompts for a
password and subsequent to entering the password (Admnistrator, admin) it
loads an empty web page.
By the way I'm using the JSP webxtenstion. I'm able to login to that URL
using mapguide meastro.
Thanks
Oshan
On Fri, Feb 12, 2010 at 2:59 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Go to your mapagent page
> Select "Feature" from "Services API"
> Click "GetCapabilities"
> Change the "Provider" field to the FDO provider you're interested in
> Hit submit and look at the functions in your resulting XML.
> - Jackie
> http://n2.nabble.com/FDO-SQL-formating-expressions-tp4512311p4559476.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100224/e181d159/attachment.html
