[mapguide-users] FDO/SQL formating expressions
Jason Birch
jason at jasonbirch.com
Tue Feb 23 21:37:22 EST 2010
There are static pages in the same directory for "testing" the
mapagent. Load index.html instead of mapagent.fcgi and you should see
this.
Jason
On 2010-02-23, icycool at inbox.com <icycool at inbox.com> wrote:
> Hey Jackie
> I have bit of problem with that. I know the Services API is in the mapagent
> folder of the webextenstion installation. I could actually load the plain
> HTML page. The problem is I'm unable to load the mapagent.fcgi in the web
> browser!
> I point to it using this URL:
> http://localhost:8008/mapguide/mapagent/mapagent.fcgi. It then prompts for a
> password and subsequent to entering the password (Admnistrator, admin) it
> loads an empty web page.
> By the way I'm using the JSP webxtenstion. I'm able to login to that URL
> using mapguide meastro.
> Thanks
> Oshan
> On Fri, Feb 12, 2010 at 2:59 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
>> Go to your mapagent page
>> Select "Feature" from "Services API"
>> Click "GetCapabilities"
>> Change the "Provider" field to the FDO provider you're interested in
>> Hit submit and look at the functions in your resulting XML.
>> - Jackie
>> View this message in context:
>> http://n2.nabble.com/FDO-SQL-formating-expressions-tp4512311p4559476.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
