[mapguide-users] URL Activated for Feature - New Window and Task Pane?
Jason Birch jason at jasonbirch.com
Sat Jan 9 14:27:40 EST 2010
If you're using flexible web layouts you can hack this functionality
by adding the hyperlink to the maptip, and manually adding the target
when concatenating the maptip together with the link.
I think it would be a reasonable enhancement request to add a new
property (url target) to the layer definition, but I'm not sure what
the interest in implementing this would be.
Jason
On 2010-01-08, Nickthetemp <nickthetemp at gmail.com> wrote:
> Hello
> I have a map application that has several layers.
> Some of these layers I would like the url activated for featre to open in a
> new window.
> Other layers I would like to open in the task pane.
> Can this be done in the same web Layout?
> Any help is appreciated.
> Thanks
> Nick MacQueen
> http://n2.nabble.com/URL-Activated-for-Feature-New-Window-and-Task-Pane-tp4273019p4273019.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
