[mapguide-users] Installation error
spatialminds
craig.miller at spatialminds.com
Mon Jan 11 23:09:36 EST 2010
Jason,
Thank you for providing an in-depth reply to the original posters question.
I am having an identical problem as the original poster on a Windows 2003
SP2 server install I'm doing. Same setup (MG 2.1.0, Windows Server 2003,
.NET dev setup, installing to IIS 6). I have been told that the Default
Website has never been renamed or deleted. The server I am installing to
has a few remnants of Microsoft Small Business Server on it, which
originally came with sharepoint, outlook web access, etc but these were long
ago removed removed.
I've created an install log and placed it at http://tinyurl.com/msilog
Thanks for any help you can lend,
Craig
Jason Birch wrote:
> Copy of my answer on "Internals":
> The installer requires that the default website still exists; for IIS6
> this
> means that both the internal ID and name are unchanged from the default.
> IIS7 I think only requires that the name is available. The important
> variables are SITE_ID and MG_WEBSITE:
> http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Installers/MapGuide/MapGuide.wxs#L51
> Which are used in:
> IIS6:
> http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Libraries/MapGuide%20Web%20Extensions/IIS.wxs
> IIS7:
> http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Libraries/MapGuide%20Web%20Extensions/IIS7.wxs
> If you have renamed or deleted the default site, the installation will
> fail.
> One of the wishlist items for the installer is a dropdown of websites to
> choose from, but it will require some development work.
> In the meantime, you can perform a manual install, and configure the IIS
> integration manually. This is a bit of a pain and not well documented;
> perhaps we should look at setting up some scripts that could be easily
> edited and run by users for this...
> If you haven't renamed / deleted the default website, we'll need you to
> enable the Windows Installer log and try again, providing us with a
> location
> to download the log from. This page shows how to enable MSI logging:
> http://support.microsoft.com/kb/223300
> Jason
> 2009/11/25 Flipper <scotth at mpowerinnovations.com>
>> Sorry Windows 200 Server on this one
>> Flipper wrote:
>> > Let me reword that a little when i said host headears I meant
>> subdomains
>> > gis.website.com wiki.website.com etc.
>> > Flipper wrote:
>> >> I'm having the same problem...We are using host headers I changed the
>> >> default back to All unassigned and its still Giving me the rollback
>> after
>> >> the Failed while
>> >> processing WebVirtualDirs (-2147024894).
>> >> HELP!!!!
>> >> Fraser Burgess wrote:
>> >>> Hi All,
>> >>> I get the following error when installing MGOS2.1: Failed while
>> >>> MGOS2.1 - IIS / .NET configuration
>> >>> Windows Server 2003 SP2
>> >>> After clicking the okay button on the error message the install rolls
>> >>> back
>> >>> Any ideas on how to fix?
>> >>> Fraser
>> >>> _______________________________________________
>> >>> mapguide-users mailing list
>> >>> mapguide-users at lists.osgeo.org
>> >>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://n2.nabble.com/Installation-error-tp3858392p4066230.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/Installation-error-tp3858392p4289743.html
