[mapguide-users] Fusion.Event.MAP_EXTENTS_CHANGED throws error
GordonL gordon.luckett at arrowgeomatics.com
Wed Jan 13 15:05:52 EST 2010
Hi Mike,
so since the mapWidget changes - should I capture it again anew?
I get this error even if I use the following code:
mapWidget.registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, alert("hi
there"));
Mike Adair wrote:
> Just a guess but it sounds like your mapWidget object changes in between
> calls.
> Mike
> GordonL wrote:
>> Hi, I am just trying to grab the current scale when the user zooms in and
>> out
>> - but after the code runs once, successfully, to throws the following
>> error:
>> Message: 'this.events[...][...]' is null or not an object
>> Line: 110
>> Char: 13
>> Code: 0
>> URI: http://localhost/mapguide2010/fusion/lib/EventMgr.js
>> the code:
>> alert(mapWidget.getScale()));
>> the code works great, once.
>    Michael Adair
>    Senior Software Architect
>    DM Solutions Group Inc.
>    Office: (613) 565-5056 x26
>    madair at dmsolutions.ca
>    http://www.dmsolutions.ca
>    http://research.dmsolutions.ca
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Fusion-Event-MAP-EXTENTS-CHANGED-throws-error-tp4365674p4368082.html
