[mapguide-users] Fusion.Event.MAP_EXTENTS_CHANGED throws error
Mike Adair madair at dmsolutions.ca
Wed Jan 13 15:19:58 EST 2010
 From your error message, the error is in the mapWidget.registerForEvent
call (not in the callback being passed as the argument) - the
MAP_EXTENTS_CHANGED  event isn't registered on the 'mapWidget' object.
You should inspect the object with firebug to see what it is and that
might give you a hint as to why it got changed.
Mike
GordonL wrote:
> Hi Mike,
> so since the mapWidget changes - should I capture it again anew?
> I get this error even if I use the following code:
> mapWidget.registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, alert("hi
> there"));
> Mike Adair wrote:
>> Just a guess but it sounds like your mapWidget object changes in between
>> calls.
>> Mike
>> GordonL wrote:
>>> Hi, I am just trying to grab the current scale when the user zooms in and
>>> out
>>> - but after the code runs once, successfully, to throws the following
>>> error:
>>> Message: 'this.events[...][...]' is null or not an object
>>> Line: 110
>>> Char: 13
>>> Code: 0
>>> URI: http://localhost/mapguide2010/fusion/lib/EventMgr.js
>>> the code:
>>> alert(mapWidget.getScale()));
>>> the code works great, once.
>>    Michael Adair
>>    Senior Software Architect
>>    DM Solutions Group Inc.
>>    Office: (613) 565-5056 x26
>>    http://www.dmsolutions.ca
>>    http://research.dmsolutions.ca
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
   Michael Adair
