[mapguide-users] Ajax Viewer and Digitizing - may be a bug
psciga
scigalla at battefeld.com
Thu Jan 14 06:48:45 EST 2010
Hi Stefan,
have you solved it? I have exactly the same Problem with the
DigitizeLineString()-function.
Regards,
Peter
S.Dalakov wrote:
> Hi all,
> I encountered a strange bug with the Ajax Viewer. I had a module for
> digitizing polygons, which was placed as InvokeURL command in the Task
> Pane. Now I transformed it to an InvokeScript command and it is started
> through the top toolbar as a part of a Flyout - drops down in a menu.
> The bug is that, when I click on this dropdown menu to activate the
> DigitizePolygon function, the first vertex of the polygon is
> automatically placed where I have clicked to activate the function - the
> point on the map that was behind the menu. My workaround in this
> situation is to fire an alert box, displaying a message, which clears
> the buffer and then everything goes like expected.
> Has any body noticed such an effect / defect / bug? Is it possible to be
> a bug in my code ?
> The behavior is the same in IE, FFox and Safari
> It is MGOS 2.02
> Stefan Dalakov
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Ajax-Viewer-and-Digitizing-may-be-a-bug-tp2216718p4392060.html
