[mapguide-users] Fusion Errors in IE8
nclayton
lord_jigg at hotmail.com
Thu Jan 14 14:21:47 EST 2010
I'm not being prompted at all. I go to the address given in the documentation
to test Fusion:
http://localhost:8008/mapguide/fusion/templates/mapguide/slate/index.html?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexibleLayouts%2fSlate.ApplicationDefinition
and I get the empty panels and a Syntax Error javascript error in
fusionFS-compressed.js (and fusionFS.js after changing the url in
index.html)
spatialminds wrote:
> Are you guys getting prompted to login? I found that I have to login as
> Anonymous/no password with IE8 to get anything to appear. With Firefox, I
> can just hit cancel when prompted to log in (a separate bug).
> Craig
> On Thu, Jan 14, 2010 at 11:15 AM, nclayton <lord_jigg at hotmail.com> wrote:
>> I am having this problem as well after using the Windows Installer for
>> mgos
>> 2.1
>> I opened index.html and changed the script path from
>> fusionSF-compressed.js
>> to fusionSF.js and the error seems to be around line 23637
>> All that is displayed are blank panels no matter what template I use.
>> I am running Windows 2003 Standard with Apache/PHP bundle
>> Ed Jobe wrote:
>> > In the templates that ship with mgos 2.1, when I use the view menu
>> > features I get an error in fusionSF-compressed-js. IE lists the error
>> as
>> > "object expected" at line 1, char 725456. If I open index.html in
>> Visual
>> > Studio, Intellisense gives a warning at line 1, column 1:
>> > Error updating JScript Intellisense: C:\Program
>> > Files\OSGeo\MapGuide\Web\www\Fusion\lib\fusionSF-compressed.js: Object
>> > doesn't support this property or method @ 0:13691
>> > It also seems to be messing up the status bar. All I get is the zoom
>> > scale.
>> View this message in context:
>> http://n2.nabble.com/Fusion-Errors-in-IE8-tp4167833p4394703.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Craig Miller
> Geospatial Software Architect
View this message in context: http://n2.nabble.com/Fusion-Errors-in-IE8-tp4167833p4394745.html
