[mapguide-users] Fusion Errors in IE8
Mike Adair madair at dmsolutions.ca
Thu Jan 14 15:04:34 EST 2010
If you aren't getting the password prompt, it could also be trying to
load an invalid resource, i.e. Slate.ApplicationDefinition isn't
available on your MG Server.
Mike
nclayton wrote:
> I'm not being prompted at all. I go to the address given in the documentation
> to test Fusion:
> http://localhost:8008/mapguide/fusion/templates/mapguide/slate/index.html?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexibleLayouts%2fSlate.ApplicationDefinition
> and I get the empty panels and a Syntax Error javascript error in
> fusionFS-compressed.js (and fusionFS.js after changing the url in
> index.html)
> spatialminds wrote:
>> Are you guys getting prompted to login?  I found that I have to login as
>> Anonymous/no password with IE8 to get anything to appear.  With Firefox, I
>> can just hit cancel when prompted to log in (a separate bug).
>> Craig
>> On Thu, Jan 14, 2010 at 11:15 AM, nclayton <lord_jigg at hotmail.com> wrote:
>>> I am having this problem as well after using the Windows Installer for
>>> mgos
>>> 2.1
>>> I opened index.html and changed the script path from
>>> fusionSF-compressed.js
>>> to fusionSF.js and the error seems to be around line 23637
>>> All that is displayed are blank panels no matter what template I use.
>>> I am running Windows 2003 Standard with Apache/PHP bundle
>>> Ed Jobe wrote:
>>>> In the templates that ship with mgos 2.1, when I use the view menu
>>>> features I get an error in fusionSF-compressed-js. IE lists the error
>>> as
>>>> "object expected" at line 1, char 725456. If I open index.html in
>>> Visual
>>>> Studio, Intellisense gives a warning at line 1, column 1:
>>>> Error updating JScript Intellisense: C:\Program
>>>> Files\OSGeo\MapGuide\Web\www\Fusion\lib\fusionSF-compressed.js: Object
>>>> doesn't support this property or method @ 0:13691
>>>> It also seems to be messing up the status bar. All I get is the zoom
>>>> scale.
>>> View this message in context:
>>> http://n2.nabble.com/Fusion-Errors-in-IE8-tp4167833p4394703.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Craig Miller
>> Geospatial Software Architect
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
