[mapguide-users] Fusion Errors in IE8
nclayton
lord_jigg at hotmail.com
Thu Jan 14 15:12:45 EST 2010
I checked and the resource exists. I may just stick to hacking up the ajax
viewer like I did in the earlier releases (I haven't had a chance to work
with it in about a year).
Mike Adair wrote:
> If you aren't getting the password prompt, it could also be trying to
> load an invalid resource, i.e. Slate.ApplicationDefinition isn't
> available on your MG Server.
> Mike
> nclayton wrote:
>> I'm not being prompted at all. I go to the address given in the
>> documentation
>> to test Fusion:
>> http://localhost:8008/mapguide/fusion/templates/mapguide/slate/index.html?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexibleLayouts%2fSlate.ApplicationDefinition
>> and I get the empty panels and a Syntax Error javascript error in
>> fusionFS-compressed.js (and fusionFS.js after changing the url in
>> index.html)
>> spatialminds wrote:
>>> Are you guys getting prompted to login? I found that I have to login as
>>> Anonymous/no password with IE8 to get anything to appear. With Firefox,
>>> I
>>> can just hit cancel when prompted to log in (a separate bug).
>>> Craig
>>> On Thu, Jan 14, 2010 at 11:15 AM, nclayton <lord_jigg at hotmail.com>
>>> wrote:
>>>> I am having this problem as well after using the Windows Installer for
>>>> mgos
>>>> 2.1
>>>> I opened index.html and changed the script path from
>>>> fusionSF-compressed.js
>>>> to fusionSF.js and the error seems to be around line 23637
>>>> All that is displayed are blank panels no matter what template I use.
>>>> I am running Windows 2003 Standard with Apache/PHP bundle
>>>> Ed Jobe wrote:
>>>>> In the templates that ship with mgos 2.1, when I use the view menu
>>>>> features I get an error in fusionSF-compressed-js. IE lists the error
>>>> as
>>>>> "object expected" at line 1, char 725456. If I open index.html in
>>>> Visual
>>>>> Studio, Intellisense gives a warning at line 1, column 1:
>>>>> Error updating JScript Intellisense: C:\Program
>>>>> Files\OSGeo\MapGuide\Web\www\Fusion\lib\fusionSF-compressed.js: Object
>>>>> doesn't support this property or method @ 0:13691
>>>>> It also seems to be messing up the status bar. All I get is the zoom
>>>>> scale.
>>>> View this message in context:
>>>> http://n2.nabble.com/Fusion-Errors-in-IE8-tp4167833p4394703.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Craig Miller
>>> Geospatial Software Architect
> Michael Adair
> Senior Software Architect
> DM Solutions Group Inc.
> Office: (613) 565-5056 x26
> madair at dmsolutions.ca
> http://www.dmsolutions.ca
> http://research.dmsolutions.ca
View this message in context: http://n2.nabble.com/Fusion-Errors-in-IE8-tp4167833p4395044.html
