[mapguide-users] RE: IIS Configuration of Mapguide OS - testing web server extensions fails
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jan 21 09:34:36 EST 2010
You probably need to allow .Net 2.0:
If it is registrered in IIS, you can go to "Extensions" and Enable it.
Otherwise, this may help:
  http://broersa.wordpress.com/2008/07/17/enable-aspnet-20-in-webservice-extensions-iis6/
You also need to look in the eventlog to see if two applications are
using the same apppool but with different .Net versions.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 21-01-2010 11:21, padmini godavarthi wrote:
> Hi Kenneth,
> Thanks for you reply.
>     Afterinstalling mapguide opensource 2.1
> 1) i found that MapguideApplicationPool was Created in the IIS.
> In side that pool therewere 3 folders created named as
> Mapadmin
> MapviewerAjax
> Mapagent
> But the mapadmin and Mapagents are working properly but i think the problem
> is with MapviewerAjax
> I previously installed Mapguide Opensource 2.0 on Windows XP but its working
> properly
> 2)Second thing is that regarding pemissions, i logged as  a system
> Administrator butweb server extensions is not working.
> Note:i dont have VS2005 in my system.only .net framework is
> there..............
> How can i resolve this problem??????????????
> Regards,
> Padmini G.
